olivasgt1 Posted January 12, 2014 Share Posted January 12, 2014 Anybody have the links to see if STI swap will fit legacy...I blew the whole motor just need something new in Link to comment Share on other sites More sharing options...
idiot4hire Posted January 12, 2014 Share Posted January 12, 2014 Easiest way is to buy a new ej257 short block and get the heads machined. Other more expiernced member have done walk through with every that needs to be done. Maxcompacity(I think that's his forum name) is well versed in this area. Link to comment Share on other sites More sharing options...
Eric Alvarez Posted January 12, 2014 Share Posted January 12, 2014 http://legacygt.com/forums/showthread.php/sti-engine-legacy-53235.html http://forums.nasioc.com/forums/showthread.php?t=2294566 My car runs a 06 sti motor in it. (05 automatic LGT) Link to comment Share on other sites More sharing options...
hobo2701 Posted January 12, 2014 Share Posted January 12, 2014 use the search bar on the top right of your screen. will answer all your questions Link to comment Share on other sites More sharing options...
careercadaver Posted January 12, 2014 Share Posted January 12, 2014 The 04-05 STI's ej257 was basically identical to the 05-07 LGT's ej255 except for the dish of the piston. The shortblock is plug and play. This would be a good time to do a head refresh and any porting and polishing you want done. There are other items which you may wish to upgrade or replace depending on why your engine failed. Oil pump an cooler would be two of the main assuming it was bearing or turbo failure related. Link to comment Share on other sites More sharing options...
MAP Posted January 12, 2014 Share Posted January 12, 2014 So what is the difference in piston surface? If the "dish" isnt the same as stock, the compression ratio will either increase or decrease. Do you know if this would make any difference on our turbocharged engines? Link to comment Share on other sites More sharing options...
careercadaver Posted January 13, 2014 Share Posted January 13, 2014 EJ257: -22cc dish EJ255: -24cc dish 255 has a higher compression ratio...I had a tune done right away so I wasn't too concerned... Link to comment Share on other sites More sharing options...
rob-2 Posted January 13, 2014 Share Posted January 13, 2014 Sorry to hear about your motor. I wouldn't bother with an STI swap. I think everyone here has told you there is little difference. Maybe you're power goals would help us all suggest a good direction. Is nothing able to be saved from your current block? Are you looking to buy a pre assembled motor ready to roll? I personally would by a short block and build it up myself. Forged pistons, bigger turbo and do so in connection with a tuner in your area. There is a lot of good info on here about different build configurations. Link to comment Share on other sites More sharing options...
boxkita Posted January 13, 2014 Share Posted January 13, 2014 ready to go engine - http://legacygt.com/forums/showthread.php/ma-ej255-longblock-and-auto-trans-219400.html this guy might still have his engine - http://legacygt.com/forums/showthread.php/nc-ej255-long-block-w-extras-218862.html Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
olivasgt1 Posted January 14, 2014 Author Share Posted January 14, 2014 Thanks guys.....yea my goal is just to get it back to just drive Link to comment Share on other sites More sharing options...
TheBlackPearl Posted January 17, 2014 Share Posted January 17, 2014 If you're doing a short block, it wouldn't matter, but the heads are different. STI's have dual AVCS vs the LGT's single AVCS. IIRC, of course. Self proclaimed PNW Craiglist find of the day Champion, April 2014. Link to comment Share on other sites More sharing options...
stealitall Posted January 17, 2014 Share Posted January 17, 2014 So what way would be cheaper and more practical rebuilding 05 LGT with Forged pistons, bigger turbo or just buy low mileage STI engine.. Link to comment Share on other sites More sharing options...
rob-2 Posted January 17, 2014 Share Posted January 17, 2014 So what way would be cheaper and more practical rebuilding 05 LGT with Forged pistons, bigger turbo or just buy low mileage STI engine.. Rebuilding the block. Link to comment Share on other sites More sharing options...
Nrw Posted January 17, 2014 Share Posted January 17, 2014 If you're doing a short block, it wouldn't matter, but the heads are different. STI's have dual AVCS vs the LGT's single AVCS. IIRC, of course. Only on the 08+ STI's for the dual AVCS. 05-06 LGT's have the same long block as 04-06 STI's. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 17, 2014 Share Posted January 17, 2014 See my click here link 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
olivasgt1 Posted January 17, 2014 Author Share Posted January 17, 2014 I think I'm convinced on just adding new parts to my motor Link to comment Share on other sites More sharing options...
Max Capacity Posted January 17, 2014 Share Posted January 17, 2014 You do know what a rebuild includes, right ? If your going to do it do it right. It's more then just, adding new parts to your motor. See my click here link 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted January 17, 2014 Share Posted January 17, 2014 -bore/hone -new bearings -new crank -new pistons -inspect heads and/or fix -new oil pickup -new water pump -new belts -Inspect turbo for play - expect to replace That's just a place to start. Expect $4-6k depending on labor and parts cost. Link to comment Share on other sites More sharing options...
hobo2701 Posted January 17, 2014 Share Posted January 17, 2014 4-6k$ fpr rebuild.. not worth it unless u are planning on some serious power. would be a lot cheaper to get a new ej255 or 257 of a vendor like infamous then just get the gates timing kit and call it a day. proly be 2-3 parts and labor most good subie guys can do a timing belt pretty quick. Link to comment Share on other sites More sharing options...
rob-2 Posted January 17, 2014 Share Posted January 17, 2014 4-6k$ fpr rebuild.. not worth it unless u are planning on some serious power. would be a lot cheaper to get a new ej255 or 257 of a vendor like infamous then just get the gates timing kit and call it a day. proly be 2-3 parts and labor most good subie guys can do a timing belt pretty quick. Best I saw a pre-built short block for was about $2k. Heads will still need to be inspected, and if he blew his motor I'm going to assume metal in oil. This means a bunch of replacements. I'd love if you could get me a new motor into my car for $3k. The time alone to reconnect everything is a days work. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 17, 2014 Share Posted January 17, 2014 4-6k$ fpr rebuild.. not worth it unless u are planning on some serious power. would be a lot cheaper to get a new ej255 or 257 of a vendor like infamous then just get the gates timing kit and call it a day. proly be 2-3 parts and labor most good subie guys can do a timing belt pretty quick. Mine was right at 6k with all the stuff I did myself. Knock on wood, it has 30,000 miles and still runs great. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
hobo2701 Posted January 17, 2014 Share Posted January 17, 2014 obviously there is gonnna be difference in pricing to swap a short block but i would see it as a two day job. maybe day and a half. infamous sells brand new ej255 for 1975.00 http://www.infamousperformance.net/servlet/the-1228/Subaru-05-dsh-06-Legacy-GT/Detail http://www.infamousperformance.net/servlet/the-75/Gates-Racing-Subaru-Timing/Detail gates kit for 168.00 proly should get some gaskets also. http://www.infamousperformance.net/servlet/the-790/Subaru-05-dsh-06-Legacy-GT/Detail gasket kit 223.00 so say 2500 for parts. two days labor @ 80$ rough average 1200-1300$ so 4K range. the thing with pulling a motor is its always easier to fix more when ur in there Link to comment Share on other sites More sharing options...
wuuusaa Posted January 17, 2014 Share Posted January 17, 2014 Get the killer b pick up oil tune while your at it. Link to comment Share on other sites More sharing options...
careercadaver Posted January 18, 2014 Share Posted January 18, 2014 I did arp head studs as well. This would be a good time to clean injectors as well... Link to comment Share on other sites More sharing options...
olivasgt1 Posted January 18, 2014 Author Share Posted January 18, 2014 Yea I know what a build consist of I just didnt want to write everything I'm going to do Link to comment Share on other sites More sharing options...
