DonnyJagaru Posted September 11, 2014 Share Posted September 11, 2014 The one on the dashboard, not the overhead console one. The owners manual is a little vague about this. http://s167.photobucket.com/user/donnyjaguar/media/airbagwarning.jpg.htmlhttp://s167.photobucket.com/user/donnyjaguar/media/airbagwarning.jpg.html Often once you re-start the engine it'll go off, but this morning it came on 10 minutes into my drive and stayed lighted. Link to comment Share on other sites More sharing options...
jdtrager Posted September 11, 2014 Share Posted September 11, 2014 You have a fault somewhere in your system. Could be an impact sensor or a seat belt, it's hard saying. You need to get it checked and they should be able to tell you what the problem is. One thing you have to remember about air bags though is if the light is on they are disabled, also it runs in a loop so after you fix the first fault, there is a chance there could be something else down the line that will not show up untill the first fault is fixed. Link to comment Share on other sites More sharing options...
jdtrager Posted September 11, 2014 Share Posted September 11, 2014 Aslo it could be as simple as a loose wire under the seat or something dumb like that. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted September 19, 2014 Author Share Posted September 19, 2014 I found instructions on Youtube on how to test, its pretty buried in there but no equipment is needed. Also found that the most common culprit is poor solder joints in the indicator lights in the overhead console. I'm an analgue designer so this will be an easy fix for me this weekend. I'll report back if it doesn't work. Link to comment Share on other sites More sharing options...
Dispatch20 Posted September 19, 2014 Share Posted September 19, 2014 Yeah, there is a post on here with the diodes and resistors in the dome light area to resolder. This seems to fix it for 95% of the cases (including my car). Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 19, 2014 Share Posted September 19, 2014 lol lead free? Link to comment Share on other sites More sharing options...
TerryD Posted September 20, 2014 Share Posted September 20, 2014 Mine does the same thing. It's irritating but haven't checked it out yet Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
