starterz Posted November 7, 2012 Share Posted November 7, 2012 I am new to the hole Subaru scene and was hoping I can get some help. I just recently purchased a 2006 Subaru Legacy 2.5i Limited. My question is how can i turn my lights all the way off? I use the light switch and my lights just get a smidge dimmer when in the off position. I'm aware of the parking light on top of the steering colum. Thanks! Link to comment Share on other sites More sharing options...
12sechatch Posted November 7, 2012 Share Posted November 7, 2012 are you talking about your daytime running lights? You want to know how to disable the daytime running lights? or, your lights dont turn off when you shut off the car...something crazy odd like that? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 7, 2012 Moderators Share Posted November 7, 2012 Are you talking about your daytime running lights? If so, you want to look at this: http://legacygt.com/forums/showthread.php/drl-disable-10-minutes-2117.html Just unplug that white plug above your pedals and bam, no more DRLs. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
trickniner Posted November 8, 2012 Share Posted November 8, 2012 FYI while BarManBean's suggestion will technically work in disabling the DRLs on the car unplugging the entire white harness plug will also disable foglight functionality and highbeam indicator on your dash. It would be best to remove the wire specific to the DRLs within the white harness and then plug it back in. That way all over accessories work correctly, just the DRLs will be disabled. Should only take a few seconds more while you're down there. Link to comment Share on other sites More sharing options...
angeltalin Posted November 9, 2012 Share Posted November 9, 2012 FYI while BarManBean's suggestion will technically work in disabling the DRLs on the car unplugging the entire white harness plug will also disable foglight functionality and highbeam indicator on your dash. It would be best to remove the wire specific to the DRLs within the white harness and then plug it back in. That way all over accessories work correctly, just the DRLs will be disabled. Should only take a few seconds more while you're down there. is this only on the 2.5i? my LGT is perfectly fine after just unplugging this StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
Drift Motion Posted November 9, 2012 Share Posted November 9, 2012 07 are diff i think Link to comment Share on other sites More sharing options...
Haight 05LGT Posted November 10, 2012 Share Posted November 10, 2012 FYI while BarManBean's suggestion will technically work in disabling the DRLs on the car unplugging the entire white harness plug will also disable foglight functionality and highbeam indicator on your dash. It would be best to remove the wire specific to the DRLs within the white harness and then plug it back in. That way all over accessories work correctly, just the DRLs will be disabled. Should only take a few seconds more while you're down there. Only on certain years. 05/06 you will be fine unplugging the entire plug. Ask me how I know. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 11, 2012 Moderators Share Posted November 11, 2012 As others have said, 05s have no issues with unplugging that plug. It controls DRLs and nothin else that im aware of. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
