malvic Posted January 12, 2010 Share Posted January 12, 2010 Does anyone here have this issue: Seat heat setting is set to the lowest level. However the left side of the seat gets very hot, to the point I've got to lift my left leg and turn off the heat. If I leave it on, it eventually cycles down, but then it becomes really hot again when the cycle start again. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted January 12, 2010 Share Posted January 12, 2010 I guess "very hot" is subjective.... I mean, yeah, it get's toasty, but not uncomfortable.... Are you sensitive to temperature change? Link to comment Share on other sites More sharing options...
ultimakf7 Posted January 12, 2010 Share Posted January 12, 2010 Or sitting in the seat naked? Link to comment Share on other sites More sharing options...
malvic Posted January 12, 2010 Author Share Posted January 12, 2010 Well, for the past 4 winters, it's been fine and nice. This year, WOW, that's hot. Like I said, the left side of the seat very hot, right nice. And no, not sensitive to temp changes. But thanks for asking. ;-) Link to comment Share on other sites More sharing options...
bluesuby Posted January 12, 2010 Share Posted January 12, 2010 I rarely use the heated seat because it's too warm for my liking. Sometimes during the winter if I'm heading for the gym and I'm wearing shorts I might have it on for a few minutes. I wish the back was heated and not the seat. Link to comment Share on other sites More sharing options...
KartRacerBoy Posted January 12, 2010 Share Posted January 12, 2010 My driver seat is like this, but the passenger seat heat is mild. I think you probably have a seat electrical issue. Search for a thread on seat heaters where the wire is apparently burned through and melting the foam of the seat cushion. I solve it by simply never using the driver seat heater since I'm always hot anyway. Link to comment Share on other sites More sharing options...
tbssubaru Posted January 12, 2010 Share Posted January 12, 2010 sometimes my driver's seat warmer gets painfully hot and i have to turn it off , other times it doesn't , dunno what's up Link to comment Share on other sites More sharing options...
Nachowang Posted January 12, 2010 Share Posted January 12, 2010 Mine went from normal to super hot (on the same left side) and now it doesnt work except for the lower back part. I didnt even know we had warmers for the lower back. Weird.... Link to comment Share on other sites More sharing options...
rice_rocket Posted January 12, 2010 Share Posted January 12, 2010 My driver seat is like this, but the passenger seat heat is mild. I think you probably have a seat electrical issue. Search for a thread on seat heaters where the wire is apparently burned through and melting the foam of the seat cushion. I solve it by simply never using the driver seat heater since I'm always hot anyway. The back is heated... And I am sure you can turn off the seat heater by disconnecting it If yours isn't working.. I may be parting out seat heater elements from my car.. PM me. Oh.. and to add, my cloth seat got really really hot fast compared to the leather.. I'm sure this has all to do with the material. The only thing I can say about your left side being hotter, I'd bet your element shifted and is wrinkled up on your left side.. hence it gets really hot. When I took apart my extra seat I noticed the seat was also wrinkled and shifted a bit. Link to comment Share on other sites More sharing options...
