No rear defrost?
my 95 legacy wagon had problems with the rear windshield last year. until my dad made me realize it was my connectors on the winshield them self. there shold be one on each side. make sure theyre connected. if theyre broken off i cant help u there for i got lucky mine were unplugged
Yes two plugs one each side, they come undone in the wagons due to closing boot over and over with force. If they're broken pop the glass and get insurance to fix it. Or attempt to fix, whatever suits
I kno at advance auto they have a repair kit in the help section if it does break
I have a wagon, and not a sedan like you but I had some trouble with my rear defroster because I broke one of the defroster tabs off. Loctite sells a defroster tab repair kit. It has conductive glue that you use to glue the tab back on. I just put some sandpaper on a flat surface and rubbed the tab back and forth to clean it off and keep it flat.
Another problem that you may have is that a conductive line (or heat bar as stasis calls them) that spans the windshield is broken. Loctite also sells a kit to fix that. You tape the glass off to make a thin line and paint the stuff on.
If it isn't either of those issues I would check the defroster tabs to make sure that power is actually getting to them.
link to heat bar/defogger kit on Amazon: [ame=http://www.amazon.com/Permatex-15067-Window-Defogger-Repair/dp/B000HBI9YQ]Amazon.com: Permatex 15067 Quick Grid Rear Window Defogger Repair Kit: Automotive[/ame]
^Do you know if there are kits to repair the actual heat bars themselves?
I was about to take a pic of it at work but we r out of stock :/
Edit: we got a truck in today and stocked the shelves. This one fixes the lines on the window ( grids) and tabshttp://img.tapatalk.com/d/12/11/03/py2ybepu.jpg
I work in auto glass, if they're broken, like monkey said, the kit works nicely. Don't pop the glass, as the rear window is incapsulated and very very expensive. Even if you have insurance, the agents are going to watch out since a 400 dollar window is going into a 14 year old car. Plus is makes for insurance rates to be higher for everyone.
With those kits, from professional experience, work as long as you let the set up for 24 hrs before re-attaching the tabs. Like stasis said check the wear under the boot, and check the tabs.
When you take off the rear pillar covers, the tabs will be sunken under the pinchweld, they wont be in plain sight.
This is the tab stuff that NAGS (National auto glass standardization) let's us use, the best from everything we have tried: http://www.frostfighter.com/prt2000.htm
And here is the same companies grid repair: http://www.frostfighter.com/prt2100.htm
Hope this helps!
