Brunex Posted May 26, 2013 Share Posted May 26, 2013 So yesterday I got a hand of a 04 Sti fuel rail. I notice that my LGT fuel rail has some sort of filter attached. Unlike the Sti's has none. My question is what is that plastic thing on my fuel rail? Looks like the Sti fuel rail might have a better fuel flow due to the lack of that plastic thing. Can I swap it? Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted May 26, 2013 Share Posted May 26, 2013 FYI, that not a filter. It's a Pulsation dumper assembly, http://opposedforces.com/parts/legacy/us_b13/type_5/intake_and_supply_system_turbocharger/intake_manifold/illustration_3/ http://forums.nasioc.com/forums/showthread.php?t=1742406 Quote from thread above. The dampers keep [ame=http://www.amazon.com/s/keywords=fuel%20pump&index=automotive]fuel pump[/ame] pulses to a minimum if a pulse...think of a wave, here..... has the valey of a pulse 'hover' over an injector....that injector may not spray fuel properly....and p0p goes the motor fuel pressure in the system is like AC power and the dampers smooth it out more like DC power. strohausii In industrial applications they use "pulsation dampeners" to minimalize stress, hammer, and cavitation generally located close to the source (think oil well pumps that look like a diesel enginehttp://images.intellitxt.com/ast/adTypes/icon1.png connected to a drum barrel electric motor) . You can actually buy "hammer arrestors" at the big hardware stores for your home plumbing, or just do what plumbers have done and create standpipes (trapped pockets of air). Fluids are practiacally uncompressible so pulses are transmitted very well, think Tsunamis. Hammer/ pulsation is to hydraulics what knock/ detonation is to engines, and quite similar. I would think that the in-line fuel filter would act more as a flow restrictor creating some minimal level of pulsation dampening unless it is truly designed with an internal feature for dampening as the devices I've described above. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
rob-2 Posted May 28, 2013 Share Posted May 28, 2013 Are your injectors not getting enough fuel? I see zero need to improve flow unless you've upgraded your injectors to exceed the stock fuel rail capacity. Link to comment Share on other sites More sharing options...
Brunex Posted May 29, 2013 Author Share Posted May 29, 2013 Thanks for the info Hammer Down! Actually I was having the rough idle and a CEL with the mysterious P000 code. The real problem was the injectors! I guess mine are out at 160k miles. Last week I bought a set of injectors from a girl that took them off her 04 Sti. Now the engine is running as silk and no more CEL The fuel rail was just a curiosity. Link to comment Share on other sites More sharing options...
