isaacpeel Posted December 10, 2008 Share Posted December 10, 2008 First of all I pretty know nothing about cars, sorry if I sound like an idiot. Last winter my car would never ever slip in the snow. I could accelerate just fine, within reason, even if I was turning. We had the first snow of the winter recently and I was sliding all over the place. Is there anything I should check out on my car? If I take it to get repaired what should I ask about? Could this be the tires, haven't changed them since I got the car in 06? A few pointers would help out a ton, thanks. Link to comment Share on other sites More sharing options...
NSFW Posted December 10, 2008 Share Posted December 10, 2008 Tires could be a factor but I'd be surprised if one year's driving could make that much difference. Snow varies a lot though... slush vs. ice, 30F vs. 20F, wet vs dry, you get the idea. Link to comment Share on other sites More sharing options...
UniqueTII Posted December 10, 2008 Share Posted December 10, 2008 A bad alignment will make your car terrible on snow. Link to comment Share on other sites More sharing options...
isaacpeel Posted December 10, 2008 Author Share Posted December 10, 2008 Tires could be a factor but I'd be surprised if one year's driving could make that much difference. Snow varies a lot though... slush vs. ice, 30F vs. 20F, wet vs dry, you get the idea. I've had my car up in the rockies countless times in all kinds of snow and temps. Something really seems to not be working at this point. I'll check out the alignment and see if that helps. Link to comment Share on other sites More sharing options...
rjundi Posted December 10, 2008 Share Posted December 10, 2008 What model Subaru and how many miles on your tires. I will only say if you have Bridgestone RE92's(factory tires on many Subaru's) after 20k-30k they lose most of their winter grip. Link to comment Share on other sites More sharing options...
isaacpeel Posted December 10, 2008 Author Share Posted December 10, 2008 What model Subaru and how many miles on your tires. I will only say if you have Bridgestone RE92's(factory tires on many Subaru's) after 20k-30k they lose most of their winter grip. it's a 2006 with just under 20k miles Link to comment Share on other sites More sharing options...
ehsnils Posted December 10, 2008 Share Posted December 10, 2008 In which way is it sliding? Front-end, rear-end or both at the same time? It may get you a hint. If you are losing grip with the rear end it's probably time to take a look at the tires. Summer tires during winter isn't good. Link to comment Share on other sites More sharing options...
isaacpeel Posted December 10, 2008 Author Share Posted December 10, 2008 it seems to be mostly the backend the tires also spin when I try to accelerate just going straight, not flooring it or anything just normal acceleration Link to comment Share on other sites More sharing options...
ehsnils Posted December 10, 2008 Share Posted December 10, 2008 In that case it's likely to be a tire issue. I recommend that you try to get a different set of wheels for winter use. Go for relatively cheap and narrow rims and equip them with good winter tires that are on the narrow side for what's specified for your car. That will give you the best grip. The difference is amazing when it comes to the amount of grip you get from winter tires compared to summer tires. Link to comment Share on other sites More sharing options...
DarkLegacy Posted December 10, 2008 Share Posted December 10, 2008 I had a '97 lgt before my '05 lgt. The 97 had a bent tie rod and the car was sliding all over the place. I would assume that having your alignment off would be a similar issue. Link to comment Share on other sites More sharing options...
rjundi Posted December 10, 2008 Share Posted December 10, 2008 it's a 2006 with just under 20k miles Assuming you have the factory RE92a's they are likely done for winter traction despite lots of tread left. I would suggest like others either investing in a winter tire/rim set from tirerack.com or putting on all-seasons biased for winter duty like the Continental ExtremeContact. All-seasons are not created equal in snow/winter capability. Sadly the factory tires (re92a) are pretty bad with this respect. Link to comment Share on other sites More sharing options...
sliCCriC Posted December 11, 2008 Share Posted December 11, 2008 find you a gravel feild floor it and see if the rear-end kicks up rocks. Link to comment Share on other sites More sharing options...
Backlash Posted December 11, 2008 Share Posted December 11, 2008 find you a gravel feild floor it and see if the rear-end kicks up rocks. then take car to paint shop to repair the rock chips isn't there a fuse to take out to basically make the car FWD? i thought i read that around here somewhere... if so, take it out and see if anything changes. but i'd go take it for an alignment check anyway, always a good thing to check. the alignment was way out on my blazer this spring... holy crap it was a pain to drive above 50mph. and i had to get on the highway (55 zone) to get to the shop to get it aligned. Link to comment Share on other sites More sharing options...
isaacpeel Posted December 11, 2008 Author Share Posted December 11, 2008 thanks for the input, I'll post again after I figure it out Link to comment Share on other sites More sharing options...
f1anatic Posted December 11, 2008 Share Posted December 11, 2008 i was about to say: after I put my Conti Extremes...driving in the snow stopped being fun: so much harder to slide the sucker around the turns. Link to comment Share on other sites More sharing options...
WhatV8 Posted December 11, 2008 Share Posted December 11, 2008 i was about to say: after I put my Conti Extremes...driving in the snow stopped being fun: so much harder to slide the sucker around the turns. Then I guess you have been 'disappointed' the past couple of days, eh? Link to comment Share on other sites More sharing options...
UniqueTII Posted December 11, 2008 Share Posted December 11, 2008 Yeah, the Conti Extremes do pretty well in the snow but get a little scary on ice. Link to comment Share on other sites More sharing options...
aigochamaloh Posted December 11, 2008 Share Posted December 11, 2008 isn't there a fuse to take out to basically make the car FWD? i thought i read that around here somewhere... if so, take it out and see if anything changes. Automatics only Link to comment Share on other sites More sharing options...
sdvictor Posted December 11, 2008 Share Posted December 11, 2008 Automatics only And only on 4EATs, if I'm correct. Besides, the dash light will go on if that fuse is out. Link to comment Share on other sites More sharing options...
05GT Guru Posted December 11, 2008 Share Posted December 11, 2008 All 05+ lgts there is no FWD fuse. Link to comment Share on other sites More sharing options...
