frostbite3360 Posted April 30, 2012 Share Posted April 30, 2012 Hey guys, been awhile since I've posted on here but I'm getting back into the game after being in Grad School the last 2 years. I seriously need some new rims, mine are ugly. I want 17 x 7's with 40mm offset. But all the websites I'm looking to buy from don't list it as fitting the 2.5i. I used to have 18" Enkei's that were 7.5" wide so I know that's not the issue. Is it because the offset is too different? I have an '05 so it came stock with the 16 x 6.5 55mm offset which I am currently running again. Link to comment Share on other sites More sharing options...
halwith Posted May 1, 2012 Share Posted May 1, 2012 there is a sticky in the wheel fitment section 4 or 5 down from n/a section. there is some info in there on the offsets. i was going to link it but failed 3 times because of this touchpad. Link to comment Share on other sites More sharing options...
thestratomaster Posted May 3, 2012 Share Posted May 3, 2012 you should be fine with a 40mm offset. go to a wheeloffset calculator and it'll tell you the difference between two wheels Link to comment Share on other sites More sharing options...
frostbite3360 Posted May 4, 2012 Author Share Posted May 4, 2012 Thanks, I've figured out that they will work. Don't know why but tirerack wasn't showing anything below 45mm offset as being compatible. Link to comment Share on other sites More sharing options...
