need advice motor consuming oil
back on January 8th I had a moment to check my oil and found it to be a quart low. quick math told me it was way too early mile wise to be that low. I looked under the car and found 2 12 inch oil circles. took it to my local dealer and the cam cover gaskets had crapped out. I had the dealer replace them. I still smelled oil smoke after freeway driving and mentioned it. It had oil on it after the repair so figured it would go away, and it did. So I'm driving down the freeway 1500 miles later going to my second job when a little red light flashes on once and goes out. couple miles down the road it does it again. I don't recognize the light so I start looking at my gauges. I see I have 17 lbs of oil pressure at 65 mph! so I exit the freeway and get to Fleet farm and get 5 quarts of oil. It takes 3.5 quarts, awesome. get it back to the dealer only to find the cam gaskets they installed had failed. They replaced everything again on their dime. now my motor is eating, not leaking 3/4 of a quart in 600 miles and I'm told my motor is on it's way out and it's my fault. Am I missing something? :spin:
Yes unfortunately you missed the memo not to take your car to the dealership for work... find a subaru specialist within driving range that you can trust to do the work for you. Good luck with everything as this sounds not so good...
03 WRB WRX (RIP)
04 JBP STI (sold)
07 DGM Legacy GT (RIP)
12 OBP STI (DD)
I guess you also missed the memo, see the last part of my sig.
You need to check the oil weekly and top it off as needed.
See my click here link on how to fix your problem.
Engine Build - Click Here
after a deeper look was taken, apparently my waste gate decided it wanted to stage 3 without telling me. and did so a number of months ago. I've been driving it like a diesel for a while just because I've been distracted in a major way for about 8 months with estate issues. turns out Subaru didn't put any kind of warning light in for over boost. So it looks like I get rebuild my motor at 127,000 miles. I really thought it would last longer. never auto crossed it. So now I'm wondering how badly the intercooler is coated? the turbo? My exhaust? how much money is this gonna cost me that I don't have?:spin:
See Max Capacity sig, CHECK your oil. If you follow that advice and check every other or third fuel fill up majority of your issues would be avoided. That all being said I don't follow that advice and by shear luck have not had a single oil related issue in 167,000 miles. Other issues yes(burned valve) but no clue of origin of that one.
Are you on the stock tune?
Seeing as I'm in it pretty deep, are there some upgrades or better parts to replace over OE? Or newer OE?
OP, you really should check out my Engine Rebuild Shopping List. It's the bare-bones, Walmart pricing of the necessary parts you'll need to get back to a stable state of motor. I'm afraid it really can't get any cheaper unless someone buys you some of the stuff, or you steal it. (Don't do that -- bad Karma, dude.)
I think there is over boost protection. I was told at 17.5 psi on teh stock map it shuts down the turbo and/or throws a massive cell.
My tuner confirmed with me I wanted that kept as protection, I said 'yes'.
Honestly, in your shoes, sell the car and get something else. I made the mistake of dropping $6k into a car worth only $10k.
