SpidermanMTL Posted July 10, 2017 Share Posted July 10, 2017 Ok.. here we go again.. going to start a new one... I currently am driving a 2016 WRX Sportech/premium.. it's leased and is due back sometime next year... so I have some wiggle room to work on the car... but space is limited so a lot of my installs have to be done in a span of like 24 hours.. eg i have to install the dp, port the turbo, install the exhaust and all the power mods in one shot.. eg friday night till saturday night... anyway. heres the list of what I own... the bigger list of wants is lower:spin: i'm trying for 1.power 2.suspension/trans 3.looks Engine Cobb Accessport v3 (ap3-sub-003) Racer X engineering Charge pipe Turbosmart Recirculating BPV Kompact Samco Cooling hoses TCS-516/C Samco Induction hoses TCS-516/I Turbo Smart Vacuum hoses Perrin TB to Intercooler hose EBCS grimmspeed +inlet adaptor Exhaust Invidia N1 dual Invidia Catted Down Pipe+ titanium heat wrap Suspension BC Br coilovers Whiteline rear differential inserts KDT903 Whiteline 22mm Adj. Rear sway bar BSR49XZ Whiteline Front Strut tower bar KSB639 Whiteline KLL122 Lateral Lock kit Megan RSTB Transmission Perrin Brass Shifter Bushing (PSPINRO16)+ 2015 WRX washer(031208006) Perrin Shifter Stop (2015 WRX) Perrin Short Shifter Adapter (psp-inr-201) Whiteline Cross member bushings positive shift kit KDT901 clutch damper delete rear diff inserts KDT903 Brakes Goodridge Brake lines 22240 Front +Rear ** Hawk Hps pads Front and Rear ** PBR BF600 Dot4 Racing Fluid ** Electric Lighting Exterior Interior Cobb shift Knob ”Red collar” Wc Latheworks Burnt Stainless Steel Shift Knob Wheels So many empty categories...lol ..... Still on the burner fuel pump dw200? dw300? oem turbo coolant line tmic Grimmspeed?...KillerB? master BCB (s687-561-b) BBK? 08+ STI front endlinks rear endlinks 2pt tie brace tub156f 687 492 rm 687 492 fm steering lockdown kit clutch + fly wheel Short throw shifter 12LGT? 2015wrx? Boomba? interior/exterior tint front lip badges grill sti vents side skirts rear diffuser rear spats 2015+sti steering wheel boost gauge red footwell leds red cup leds red cubby leds shift boot reverse lockout ill sill plates puddle lights 2014 apearence package headlights -hi -low -tails -brake -reverse -fogs -switchbacks? led relay ***tapturn*** More to come.... MY BUILD TAKE 2 : http://legacygt.com/forums/showthread.php/spideys-12lgt-take-2-266018.html Link to comment Share on other sites More sharing options...
Zee199969 Posted July 10, 2017 Share Posted July 10, 2017 if you find that Cusco MCB lemme know My "Build" Link to comment Share on other sites More sharing options...
Humble Rumble Posted July 10, 2017 Share Posted July 10, 2017 if you find that Cusco MCB lemme know Did you miss out on the FB group buy for the clone? Or are you after an original one? 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
SpidermanMTL Posted July 10, 2017 Author Share Posted July 10, 2017 They were stupid hard to find 5 years ago and they are even harder to find these days.. MY BUILD TAKE 2 : http://legacygt.com/forums/showthread.php/spideys-12lgt-take-2-266018.html Link to comment Share on other sites More sharing options...
