LegacyDan Posted January 26, 2011 Share Posted January 26, 2011 Im looking to fit an adjustable actuator to the new vf36 turbo i bought recently and im wondering what would be the best one to go for. I heard the stock one is pretty weak and doesnt hold boost well over 5k rpm. Anyone have some recommendations? Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted January 26, 2011 Share Posted January 26, 2011 I don't know much about the VF36 but most adjustable wastegate actuators are just a universal part: http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TP&Product_Code=ATP-WGT-031&Category_Code= http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TP&Product_Code=ATP-WGT-009&Category_Code= I've never even seen a VF36 because they were never sold in the US, but I would be reluctant to spend time and money on an actuator for a stock turbo. If you use a 3 port boost control solenoid and perhaps adjust the stock actuator a bit it's going to hold boost well enough. A stock turbo is going to run out of efficiency up top anyway. On the search for a new DD... Link to comment Share on other sites More sharing options...
LegacyDan Posted January 26, 2011 Author Share Posted January 26, 2011 looks like this: http://i32.photobucket.com/albums/d3/desperatedano/IMG_20110125_140230.jpg How can you adjust the stock actuator? I was looking to get an adjustable actuator as i need to rotate up the compressor housing so it bolts up to TMIC, the stock actuator will probably be in the way Link to comment Share on other sites More sharing options...
Deaks2 Posted January 28, 2011 Share Posted January 28, 2011 I would think the VF-36 and VF-37 actuators are identical. Mine is fine at high revs. Link to comment Share on other sites More sharing options...
SonicSpecB Posted January 28, 2011 Share Posted January 28, 2011 What TMIC are you going to run? Link to comment Share on other sites More sharing options...
LegacyDan Posted January 28, 2011 Author Share Posted January 28, 2011 will be sticking with the stock TMIC for now. i need to rotate the compressor housing so that the turbo inlet points vertical instead of horizontal so i can connect to the stock top mount. because of this the actuator bracket needs modification. So went from this: http://i32.photobucket.com/albums/d3/desperatedano/IMG_20110125_135108.jpg to this: http://i32.photobucket.com/albums/d3/desperatedano/IMG_20110127_181344.jpg I came across this: http://cgi.ebay.ie/ws/eBayISAPI.dll?ViewItem&item=280616228677&ssPageName=STRK:MEWAX:IT#ht_1852wt_1139 It looks like it has an adjustable bracket which should do the job and the actuator shaft looks like it has a bit of adjustment on it too. My tuner told me to go for one that will crack open at about 1 bar Link to comment Share on other sites More sharing options...
SonicSpecB Posted January 29, 2011 Share Posted January 29, 2011 Nice if this works gimme a shout i've got a VF 37 to install and was thinking bout rotating the housing to fit on my HKS TMIC. Link to comment Share on other sites More sharing options...
LegacyDan Posted January 29, 2011 Author Share Posted January 29, 2011 Nice if this works gimme a shout i've got a VF 37 to install and was thinking bout rotating the housing to fit on my HKS TMIC. it does work,i know a guy on another forum thats done it. you need to change DP UP and headers to though for bolt on fit or else lots of custom pipework modified actuator bracket: http://i32.photobucket.com/albums/d3/desperatedano/DSCF0317-Small.jpg custom silicone intercooler pipe: http://i32.photobucket.com/albums/d3/desperatedano/DSCF0315-Small.jpg Small bit of modification needed to connect to stock centre cat section with 3" DP http://i32.photobucket.com/albums/d3/desperatedano/DSCF0320-Small.jpg Link to comment Share on other sites More sharing options...
underpowerd Posted January 29, 2011 Share Posted January 29, 2011 i love my forge awga; not sure if they have a model for the 36 though. but they are very serviceable (basically you can take everything apart into peices) might be worth a retrofit with a custom bracket, if possible. you can buy the 4-spring set and go from ~7 to ~25 psi. Link to comment Share on other sites More sharing options...
LegacyDan Posted February 12, 2011 Author Share Posted February 12, 2011 Nice if this works gimme a shout i've got a VF 37 to install and was thinking bout rotating the housing to fit on my HKS TMIC. so i got a chance to fit this onto the vf36 today and it took me a whole 10 mins to install, much easier to do when turbo is not in the car! http://i32.photobucket.com/albums/d3/desperatedano/DSC_7416.jpg http://i32.photobucket.com/albums/d3/desperatedano/DSC_7417.jpg http://i32.photobucket.com/albums/d3/desperatedano/DSC_7418.jpg Link to comment Share on other sites More sharing options...
Deaks2 Posted February 12, 2011 Share Posted February 12, 2011 Neat. Can you show me what your TMIC looks like? Link to comment Share on other sites More sharing options...
LegacyDan Posted February 12, 2011 Author Share Posted February 12, 2011 im still on standard tmic but heres how it looks using standatd tmic, just a silicone elbow needed instead. heres the HKS one sonic has i think: http://img708.imageshack.us/img708/7160/46866199.jpg Link to comment Share on other sites More sharing options...
SonicSpecB Posted February 12, 2011 Share Posted February 12, 2011 How much psi is set on that actuator? Link to comment Share on other sites More sharing options...
mwiener2 Posted February 12, 2011 Share Posted February 12, 2011 you need a bigger turbo, not a bigger actuator My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
LegacyDan Posted February 13, 2011 Author Share Posted February 13, 2011 you need a bigger turbo, not a bigger actuator so whats wrong with the vf36? its good for about 310-320whp. And who said i got a bigger actuator? Link to comment Share on other sites More sharing options...
mwiener2 Posted February 13, 2011 Share Posted February 13, 2011 by adjusting the actuator tighter, you are essentially increasing the spring size, thus a larger actuator there's nothing wrong with that turbo... it's just an oem size turbo. It's gonna run out of steam at the higher RPM's. A larger actuator will help hold the door closed, but you are running way out of the efficiency range. It's a flamethrower at that point. The only solution is a larger turbo My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
LegacyDan Posted February 13, 2011 Author Share Posted February 13, 2011 the main reason i got this actuator was because it can bolt on to vf36 with rotated compressor housing, standard one, i would need to modify the bracket which would be a pain in the ass.standard one opens at about .8 bar new one opens at 1 bar so not a huge difference between them Link to comment Share on other sites More sharing options...
