gregdell1121 Posted May 20, 2010 Share Posted May 20, 2010 hey guys i have a 97 gt and it has 117k on it. i had recently noticed that when parking my car there would be coolant on the ground the next morning. then today i was running the engine pretty hard and the temp needle started rising rapidly so i pulled over and turn the car off immediatly. i looked under the hood and the overflow tank was full. I know that this is a usual symptom of a blown head gasket but they were just replaced at 100k miles. so what else could be causing that? where or how should i start trouble shooting? thanks in advanced Link to comment Share on other sites More sharing options...
gregdell1121 Posted May 20, 2010 Author Share Posted May 20, 2010 a little more info. i did a visual check on the radiator cap and it looked fine(but i know that it still could be faulty) and checked the level in the radiator. is it supposed to be completely full to the top? cause it was about 2 or 3 inches from the lip of the spout. i ran the car until it was at normal running temp(just about half way on the temp gauge) and didn't see any bubbling in the overflow tank and the coolant was at the correct level in the tank. Link to comment Share on other sites More sharing options...
thestratomaster Posted May 26, 2010 Share Posted May 26, 2010 The radiator could be cracked. That happened to an accord I had a while back. Link to comment Share on other sites More sharing options...
fu2ufer Posted June 24, 2010 Share Posted June 24, 2010 This is happening on my 91 2.2L right now also. I just replaced the head gaskets last year but go some cheap off brand ones. Are you still having the issue and if not, what was done to fix it? Link to comment Share on other sites More sharing options...
Malt Beverage Posted June 25, 2010 Share Posted June 25, 2010 I remember reading a TSB about the legacy having issues pulling in crap from the bottom of the coolant reservoir and jamming up the cap pressure valve in the process. This would cause the coolant reservoir to constantly over flow because the system will not hold pressure. Clean out your holding tank and start with a cap. If the system still leaks have it pressure tested. Link to comment Share on other sites More sharing options...
gregdell1121 Posted June 25, 2010 Author Share Posted June 25, 2010 yeah turns out the head gaskets were never replaced...i noticed the head bolts had never been touched, pulled the engine and vula, blown head gaskets. i replaced them and all is good. Link to comment Share on other sites More sharing options...
Malt Beverage Posted June 26, 2010 Share Posted June 26, 2010 Cool, though it sounds way easier in writing then I'm sure it was. Link to comment Share on other sites More sharing options...
gregdell1121 Posted June 28, 2010 Author Share Posted June 28, 2010 oh yeah it was a ton of work, about 15 hours total labor and $500 in parts and machine shop charges. and diagnosing it was any fun either, i replaced the thermostat twice and the radiatior cap twice and pressure tested the system prolly 6 times lol. i wanted to be CERTAIN that the head gaskets were the problem. but im glad its all done with now though. but my rear diff is making horrible noises so thats my next problem to tackle...ill probably just put a used lsd in. Oh well, its worth it, i love my car. Link to comment Share on other sites More sharing options...
Malt Beverage Posted June 28, 2010 Share Posted June 28, 2010 And it never ends. My 05 is around 92k now. Just did the valve cover gaskets today, the rear wheel bearings are smoked, up soon for a timing belt. I miss when it only had 20k. Good thing I like fixing things. Link to comment Share on other sites More sharing options...
