05wagongt Posted February 23, 2013 Share Posted February 23, 2013 ok, on both my driver and passenger front door panels, the handle that you use to pull the door shut is coming off the silver trim it connects too, i tried searching and found no answer-is it possible to just replace the silver trim piece and door handle? or do i need all new door panels? Link to comment Share on other sites More sharing options...
Rusty9 Posted February 27, 2013 Share Posted February 27, 2013 It would be a pain to replace just that section because last time I looked that section is secured by melted plastic rivets. Possible to drill them out and secure a replacement, sure, but an entire used panel would be easier to install. Link to comment Share on other sites More sharing options...
05wagongt Posted March 13, 2013 Author Share Posted March 13, 2013 thanks, just sucks because rest of door panelis fine, have to replace 2 door panles for 2 dumb black handles blows... Link to comment Share on other sites More sharing options...
Dbl_D718 Posted March 14, 2013 Share Posted March 14, 2013 You just need to pop off the removable half of the handle and tighten down the screws inside of it. Explanation here: http://legacygt.com/forums/showthread.php/door-panel-removal-sound-deadening-install-pics-20069.html MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
05wagongt Posted March 14, 2013 Author Share Posted March 14, 2013 You just need to pop off the removable half of the handle and tighten down the screws inside of it. Explanation here: http://legacygt.com/forums/showthread.php/door-panel-removal-sound-deadening-install-pics-20069.html thank you!!!!!!!!!!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
