time4turbo Posted October 26, 2010 Share Posted October 26, 2010 I just installed HIDs on my 07 LGT. After disabling my DRLs by pulling out the white plug down by the clutch pedal (next to a black plug) my fog lights would no longer work. Nothing happened not even on the guage cluster when I turned the switch on and off for the fogs. Once I plugged it back in the fogs worked again. I want to disable my DRLs but still keep use of the fogs. Any help please??? Link to comment Share on other sites More sharing options...
GTS Jeff Posted October 29, 2010 Share Posted October 29, 2010 You'll have to confirm this (ie. search) but IIRC, the unplug only works for 05-06 and for 07 you need to cut a blue wire somewhere. I think I read that while I was researching, but I have an 05 so I'm not positive. GL. Link to comment Share on other sites More sharing options...
