SGVLeggy23 Posted July 31, 2013 Share Posted July 31, 2013 Check engine light is on an the "cruise " light blinks. Any suggestions of what it could be and how to fix? Got a road trip coming up and i need my baby to be ready. Car runs perfect to me. Cant feel any difference in performance Sent from my SCH-I535 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Max Capacity Posted July 31, 2013 Share Posted July 31, 2013 Have you done a web search for that code ? system to lean. When you get a CEL the CC is disabled. http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
heiche Posted July 31, 2013 Share Posted July 31, 2013 could you pull a learning view and post it here please? your air/fuel ratio is way off so you probably should take it easy until it is resolved. one preliminary guess would be a big air leak like the turbo inlet hose torn where it connects to the turbo, but more info would help. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 31, 2013 Share Posted July 31, 2013 could you pull a learning view and post it here please? your air/fuel ratio is way off so you probably should take it easy until it is resolved. one preliminary guess would be a big air leak like the turbo inlet hose torn where it connects to the turbo, but more info would help. +1. Check for vacuum leaks. Link to comment Share on other sites More sharing options...
