kd77591 Posted October 6, 2011 Share Posted October 6, 2011 So i have a big problem or my Subie is possessed! i own a 2006 Legacy GT, EA trans, aftermarket turbo, new motor and internals, Cobb SS Down-pipe, manga-flow exhaust, about two weeks ago i blew the turbo coolant hose. engine heated up real good but not in the red thank god! So i fixed that mess and now as of last week of so my car drives fine in electronic manual 1st thru 5th, and fine in sport mode but when i put it in standard drive, it won't hold constant boost at full throttle, and it has a real strange sound when i hard accelerate ( almost like strapping a cherry bomb glass pack to the exhaust system a real hollow sound) I have searched through every topic in the troubleshooting forums on here and nothing as of yet has help me find the culprits. Please any help is sooo greatly appreciated. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 6, 2011 Share Posted October 6, 2011 I don't understand automatics, why would it only make the noise in one driving mode and not the others. Make first guess is a vacuum leak. PM ClimberD, he is real good with automatics. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bmx045 Posted October 6, 2011 Share Posted October 6, 2011 line pressure is higher in manual modes. Link to comment Share on other sites More sharing options...
kd77591 Posted October 6, 2011 Author Share Posted October 6, 2011 okay, not trying to sound like an idiot but whats that mean? better yet what should i be looking for to fix/ repair it? Link to comment Share on other sites More sharing options...
bmx045 Posted October 6, 2011 Share Posted October 6, 2011 we really need more information. could be your tranny slipping. the tcu calls for less clutch pack line pressure when in standard D mode, manual modes call for more pressure. Clutches may be slipping in D. but boost leaks can make weird noises too, check your throttle body hose and make sure all hose clamps are snug. Link to comment Share on other sites More sharing options...
kd77591 Posted October 6, 2011 Author Share Posted October 6, 2011 ok so, basically take it in and get her checked out. Link to comment Share on other sites More sharing options...
bmx045 Posted October 6, 2011 Share Posted October 6, 2011 since you're dumbfounded, yes. Link to comment Share on other sites More sharing options...
kd77591 Posted October 6, 2011 Author Share Posted October 6, 2011 not dumbfounded just totally new to turbo's and Subaru engines, ets. my expertise is jeeps and Rams, Link to comment Share on other sites More sharing options...
bmx045 Posted October 6, 2011 Share Posted October 6, 2011 well search for blown off tube or loose hose clamps throughout the intake and intercooler system, if nothing amiss then take it in Link to comment Share on other sites More sharing options...
kd77591 Posted October 6, 2011 Author Share Posted October 6, 2011 sounds like a plan, i'll take a look this weekend in my nice heated garage! Link to comment Share on other sites More sharing options...
Max Capacity Posted October 6, 2011 Share Posted October 6, 2011 You won't need a heated garage this weekend. But I'll keep you in mind.... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
