khurlburt Posted December 7, 2013 Share Posted December 7, 2013 So I just had all my accessory belts replaced today and on the drive home I noticed that my reading for boost on my ap is not moving. At all. it's sitting at 0.1 and will move occasionally to an even 0.0. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
GTEASER Posted December 7, 2013 Share Posted December 7, 2013 How does the car drive? Like it has no power? Based on your symptom of the gauge not moving at all, my guess is the vacuum hose for the boost gauge was not reconnected or fell off while they were working on it. Trace it from the firewall or MAP sensor to where it was plugged into the intake manifold or other vacuum lines and make sure it is connected or reconnect it. And then zip tie it on. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
khurlburt Posted December 7, 2013 Author Share Posted December 7, 2013 The car doesn't feel all that different, and I'm using my accessport as the boost gauge so there's no vacuum lines. But thanks for that advice, cause if I was using a gauge I bet that'd be the first thing to check. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
iNVAR Posted December 7, 2013 Share Posted December 7, 2013 map sensor line not connected. you better fix that asap. http://legacygt.com/forums/showthread.php/vacuum-linesi-map-sensori-184259.html?p=3856299 Link to comment Share on other sites More sharing options...
khurlburt Posted December 8, 2013 Author Share Posted December 8, 2013 Yep that's what It was! They're all zip tied and good to go. Thanks Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
