obxt Posted October 26, 2005 Share Posted October 26, 2005 I installed a Harmon Kardon Drive + Play last week. I used Jazzy’s Aux Input board which works great! Overall I’m very happy with the unit, but the interface does not exactly duplicate the iPod interface. Some of the limitations are: Responsiveness is a bit sluggishThe outer ring of the controller is not a wheel, as on the iPod, just a 3 position switch (Reverse-Off-Forward) with no variable speed, and not nearly as smooth as the ipod wheel.No good way to navigate through very long Audiobooks or Podcasts.You can’t play “All” songs from a single artist as on the iPod; you can only play all the songs from a single album. Doesn’t display time remaining for songs, or indicate how far into the track you are.No direct access to Podcast or Audiobook list as on the ipod – must go through genre.No access to iPod “extras” such as contacts or calendar. On the plus side, the idea of having the controller and display separated works very well, and is safer than controlling the iPod directly. It automatically starts/stops with the ignition switch and “remembers” where the ipod was paused, even if it was playing through headphones or other speakers when it was paused. Also, the extra aux input will be useful for anyone who wants to also install a Satellite radio,etc. Overall, it still seems to be the best iPod integration for the Subaru, allows browsing all music, and it sounds great. The display is permanently mounted in the cubby. It sits to the left, I can still easily slip a pair of sunglasses behind it, and the door still closes fine. I cut away a section of the top of the cubby using a coping saw and files. I removed the mounting bracket supplied with the unit, and instead used a pair of #4-40 screws to attach the display to the bottom of the cubby. I drilled the holes very carefully by hand, putting through holes in the cubby and tapped threads in the display. I ran the wire out through the top. I also disconnected the cubby light, and removed the annoying yellow warning sticker. I may disassemble the display unit, and make a custom bezel which integrates better with the Subaru interior styling. The electronics enclosure sits behind the cubby, and I ran wires to the fuse box area for power. I went ahead and plugged in an extra cable to the “Aux in” jack, and ran it into the glove box, so I can connect an XM, Computer, or whatever in the future. I haven’t tried it yet, but it’s supposed to be “auto sensing”, so it will automatically switch to the aux in whenever there’s a signal. The controller is mounted to the lower right of the gearshift, using the 0 degree mount supplied. I used the double sided tape supplied with the kit, which holds it very securely. The wire runs out the rear of the base, and slips under the edge of the plastic center unit. I cut a small notch (not visible) in the underside of the plastic to prevent the wire from getting pinched. Unfortunately, the area for the mounting flange is a little tight, and it slightly overhangs the gear shift boot. I may make a custom mount with a smaller base in the future. I’m also curious if it’s possible to replace the blue light in the controller with a red one (I’m guessing it’s just an LED) which would match the other console lights. I ran the iPod connector into the armrest storage bin. I had to drill a 15/32 hole for the connector to pass through. I may replace the connector with an actual iPod dock to make it easier to connect and keep it from floating around in the bin. I still would like to have a better way to switch to the iPod input, ideally using the “hidden” SAT switch on the factory HU and not requiring the blank CD,. I know Jazzy’s working on a next generation interface board, and there are a couple other threads addressing this issue: http://legacygt.com/forums/showthread.php?t=18870http://www.legacygt.com/forums/showthread.php?t=21047) For now Jazzy’s board is a very good non destructive solution. Here are some pics of the install: Link to comment Share on other sites More sharing options...
jazzymt Posted October 26, 2005 Share Posted October 26, 2005 All I can say is...you must be a machinist Very nice install. If I had an iPod I would def consider using this slick little device. [CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER] Link to comment Share on other sites More sharing options...
NatesGr8 Posted October 26, 2005 Share Posted October 26, 2005 All I can say is...you must be a machinist Very nice install. If I had an iPod I would def consider using this slick little device. Quick everyone, lets buy jazzy an ipod so he can get working on his version 2 board with the display and controls interface. And nice setup obxt, very impressive. Link to comment Share on other sites More sharing options...
The Mayor Posted October 27, 2005 Share Posted October 27, 2005 My hero! I am placing my order today for the HK...I have Jazzy's board and will install them all together. Questions: are you able to close the cubby door? Did you consider mounting and hardwiring the controller unit where it is now? Thanks for the great write up! Link to comment Share on other sites More sharing options...
obxt Posted October 27, 2005 Author Share Posted October 27, 2005 Yes, the door closes just fine. I will probably run the controller wire through a hole in the console after I make a smaller custom base for it. I'll probably still use the double stick tape to mount it - it's amazingly strong. Link to comment Share on other sites More sharing options...
executor485 Posted October 27, 2005 Share Posted October 27, 2005 My only problem with the Harmon Kardon one... its SOOOO freaking expensive. At least if its the same model I looked at from Circuit City... Ughhh to the pocket book. Other than that... great install. Enjoy If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
c_hunter Posted October 28, 2005 Share Posted October 28, 2005 Thanks for the great writeup -- I have been hoping someone would try this out! Nice work too. FWIW, most of the iPod interfaces are slow -- I believe it's due to the serial interface of the iPod dock connector or something. I'm thinking I might install one of these too. Craig Link to comment Share on other sites More sharing options...
motion_157 Posted October 28, 2005 Share Posted October 28, 2005 Great install and review. I'm also going with the HK Drive+Play. In my opinion, it's the best option for an iPod connection. While there'll never be a device that works as good as the actual iPod for browsing the music, I think this one comes pretty damn close. The only odd thing is that you mentioned you can't play all songs by an artist, it just seems like that should work. Link to comment Share on other sites More sharing options...
pathung Posted December 22, 2005 Share Posted December 22, 2005 My question is, how do you start taking all these panels off and cubbies out? I wonder if Jazzy's kit provides instructions for that - I just placed my order. Link to comment Share on other sites More sharing options...
heybige Posted December 22, 2005 Share Posted December 22, 2005 The answer to all your questions is below.... http://legacygt.com/forums/search.php Link to comment Share on other sites More sharing options...
pathung Posted December 22, 2005 Share Posted December 22, 2005 heybige, If the SEARCH button is omniscient, no one needs ever post questions again, since all questions have been asked, and should never be repeated... or is that the case? Additionally, why assume that someone has NOT already conducted a search before posing a question? Let's not be condescending without first obtaining relevant information; then again, perhaps one should never be condescending? I like the latter. Link to comment Share on other sites More sharing options...
heybige Posted December 22, 2005 Share Posted December 22, 2005 Pathung - philosophy aside, you've asked several questions on this topic. I personally have tried helping you with this. The answers are out there. If my assumption that you haven't searched is wrong, I apologize. Whatever you choose to do, good luck. Link to comment Share on other sites More sharing options...
rebourne Posted April 11, 2006 Share Posted April 11, 2006 dood OBXT you rock! I have a Drive+Play in the box that I got for Xmas. I've wasn't sure how well it would fit in the cubby, nor how much I had to cut. your pics are awesome, as well as the quote about the double sticky tape. I'm leasing my GT so i have to be careful about holes n stuff. Can wait for the weekend, im gonna finally install that thing!! pic thread build thread Link to comment Share on other sites More sharing options...
leftride Posted April 11, 2006 Share Posted April 11, 2006 rebourne, dont have any step by step pics, but did a similar install and there was no cutting of plastic pieces. http://www.legacygt.com/forums/showthread.php?t=30888 just for another option.. *vb gallery* Link to comment Share on other sites More sharing options...
rebourne Posted April 11, 2006 Share Posted April 11, 2006 ya, i saw yours and liked it alot. Nice work. I sent the pics of yours to my friend that works at JBL (parent of HK, and now you know you gave me the D+P ;-) ). But I also like the cubby for stashing stuff in. I was thinking of something like yours, but off to the side, leaving the right side of the cubby open. but if i make it too complicated, i know what will happen... i'll get lazy and not do it. :-/ pic thread build thread Link to comment Share on other sites More sharing options...
leftride Posted April 11, 2006 Share Posted April 11, 2006 yeah, the cubby is nice. the best install i think, would be, as tobecontinued said in my thread, to put the monitor in the door. it would take more fabrication and would be quite a bit more difficult. *vb gallery* Link to comment Share on other sites More sharing options...
tintinet Posted April 17, 2006 Share Posted April 17, 2006 I've been considering the HK D&P also. I have an FM transmitter, but I've found its fidelity and volume capabilities unsatisfactory, especially when I usually play Green Day at sub-woofer enhanced car bouncing volume levels. My upper "cubby" is already taken by the Perfomance Gauge Pack, so I have a bit of a dillema regading the display placement. I'd really rather not clutter up the dash with add-ons. Link to comment Share on other sites More sharing options...
rebourne Posted April 17, 2006 Share Posted April 17, 2006 I played around (just holding the display) and it would work pretty good on the headliner near the mirror. Kind of a heads -way- up mount. I was thinking I could get it to fit right above and just a hair behind the mirror. But then I think about hiding the wire, and i go back to the cubby idea. If you're less lazy than me, it looks like a good option. pic thread build thread Link to comment Share on other sites More sharing options...
mlrtime Posted July 16, 2006 Share Posted July 16, 2006 CC has this on sale if anyone is interested... Buy the Harman Kardon Drive + Play (DP1US) and other iPod nano Accessories at circuitcity.com Link to comment Share on other sites More sharing options...
litlmatt Posted September 7, 2006 Share Posted September 7, 2006 hello all, i have been hiding in the background reading up on all things legacy and was wondering if anyone was able to change the drive+play control knob color from blue to red? thanks. newbie matt Link to comment Share on other sites More sharing options...
ScottDP284 Posted December 9, 2006 Share Posted December 9, 2006 Sorry for bump of old thread - the HK Drive + Play is on sale at Crutchfield right now for $100 and they throw in the wired transmitter for free. $100 was the price for me, figured it might be the same for others. Leftride and obxt - excellent installs. I'll def be using them as a guide. Link to comment Share on other sites More sharing options...
tintinet Posted December 9, 2006 Share Posted December 9, 2006 No apology required! Thank for the tip! Some potential additional savings: Fatwallet Link Link to comment Share on other sites More sharing options...
bosco Posted December 10, 2006 Share Posted December 10, 2006 i had the D+P took it out and did this. have since taken electrical tape off looks better. charges i-pod, controls easy to use. jazzy aux> david navone (charger)> pro clip (holder) > i-pod, done. bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
mlrtime Posted December 10, 2006 Share Posted December 10, 2006 What piece is that? Link please? Link to comment Share on other sites More sharing options...
bosco Posted December 10, 2006 Share Posted December 10, 2006 What piece is that? Link please? http://www.proclipusa.com lots of cool holders/brackets for ipod, phones, GPS, etc., well made. bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
