Prothane LCA bushings
benena
Yes, it contains both. There is also a total kit with several bushings for a good buy. Here is a post in a thread from about a week ago with part numbers:
You will be fine. Might I add that if you don't want to do the caster correction you might just buy the prothane kits as they are pretty cheap. Here is a breakdown of part numbers and prices (total kit is best buy).
Total kit (contains all three below): Prothane 162004 ($105)
Rear diff: Prothane 161609 ($35)
Front control arms: Prothane 16303 ($50)
Steering rack bushings: Prothane 16701 ($40)
Polyurethane is polyurethane; you are paying for the name with whiteline. Nothing against whiteline as they make some great products that are unique to our cars, but the bushings are basic.
Prothane has been around for a long time. I'm due for another set of front LCA bushings and I think I'm going to give them a try. The large bushing in the front has no metal around the outside and they have the 2 voids like the OE design. They are cheap enough for an experiment.
  • 1 month later...
  • 10 months later...
