ibchunkyboy Posted August 8, 2013 Share Posted August 8, 2013 Ok i have a alpine type r in a ported box in the back of my 07 Legacy, i have another one i wanna put in a dual ported 12 inch box but this stupid seatbelt recoild seems to be ******* my install up. does anyone have 2 12's in the back of there subie? or any ideas around it? custom box build? Link to comment Share on other sites More sharing options...
rweezy Posted August 8, 2013 Share Posted August 8, 2013 I have two 12's in the back of mine. Go with a sealed box instead of ported. Sealed are generally smaller. It was a tight fit but it works. Something like this [ame=http://www.amazon.com/Bbox-12-Inch-Subwoofer-Enclosure-Charcoal/dp/B0013MV7CY/ref=sr_1_11?s=electronics&ie=UTF8&qid=1375991297&sr=1-11&keywords=atrend+12+%22]http://www.amazon.com/Bbox-12-Inch-Subwoofer-Enclosure-Charcoal/dp/B0013MV7CY/ref=sr_1_11?s=electronics&ie=UTF8&qid=1375991297&sr=1-11&keywords=atrend+12+%22[/ame] should work. Not sure if that's exactly what I got but you get the idea. Link to comment Share on other sites More sharing options...
subymike Posted August 8, 2013 Share Posted August 8, 2013 i had 2 12" pioneer premiers in a ported box in the back of mine. had the same problem so i just took the middle seat belt out all together. worked fine after that 06 GT - Totalled ... to be continued 07 Spec B - Wife took over 06 i - getting built motor and 6 speed Link to comment Share on other sites More sharing options...
tDoug60 Posted August 8, 2013 Share Posted August 8, 2013 I'm trying to figure out to run a sub with the stock head unit Sent from my SAMSUNG-SGH-I337 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Ghostride Posted August 8, 2013 Share Posted August 8, 2013 If you want to run an aftermarket sub and amp you need to get a line level converter, tap into the speaker outputs behind the radio and run RCA's from that to where you want to mount you amp. I'm trying to figure out to run a sub with the stock head unit Sent from my SAMSUNG-SGH-I337 using Tapatalk 2 Link to comment Share on other sites More sharing options...
subymike Posted August 9, 2013 Share Posted August 9, 2013 ^ what he said. 06 GT - Totalled ... to be continued 07 Spec B - Wife took over 06 i - getting built motor and 6 speed Link to comment Share on other sites More sharing options...
tDoug60 Posted August 9, 2013 Share Posted August 9, 2013 Any walk thru for taking stock radio out Sent from my SAMSUNG-SGH-I337 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Mega Users LieutenantDan Posted August 9, 2013 Mega Users Share Posted August 9, 2013 http://legacygt.com/forums/showthread.php/plug-n-play-aux-mod-2005-6cd-radios-18504.html?t=18504&highlight=jazzy Click on the link under instructions and you get a printable pdf with pictures Link to comment Share on other sites More sharing options...
