Intermittent grinding/squealing from pass. front wheel?
Symptoms: loud grinding, squealing sound from front of car, no change in volume or pitch when brakes are applied.
Frequency: Twice in the last 2 days, but for maybe less than a mile (I pulled over to inspect (because paranoia), and when I pulled away it was gone.
Possible causes:
-They recently filled potholes by my work with fine gravel, I'm thinking maybe I'm getting some contamination on my pads?
-Seized caliper
-wheel bearing
Thoughts? Thanks!
I assume you know the pads have pad left on them and are not getting low or closed to needing replacement ?
They're getting low, but shouldn't be low enough to cause intermittent problems. I would think that if they were low enough to grind, it would be constant.
