ALTER Posted October 4, 2009 Share Posted October 4, 2009 Can someone explain the two for me? ive tried google search, and everything that came up didnt make sense. Can any of you explain to me better? Also, can you explain what RPM has to do with both horsepower and tourqe too? Thanks alot guys Link to comment Share on other sites More sharing options...
johnAWD Posted October 4, 2009 Share Posted October 4, 2009 Caveat - blatantly borrowed. Horsepower is a measure of the amount of Work the engine does over a given Time. The basic definition of Work is: Work = Force x Distance Therefor: Horsepower = ( Force x Distance ) / Time But what we are talking about here is the relationship between Horsepower and Torque. Torque is basically the force that we are talking about in the above equation. So if we substitute that, and clean things up a bit, what we are left with is the following equation: Horsepower = (Torque X RPM ) / 5252 This actually tells us a lot of interesting things. The first is that at 5252 RPM, an engine’s Horsepower should equal its Torque. I think that you will find that if you look at pretty much any dyno plot of any car, the torque curve and horsepower curve will cross right around 5,200 rpm’s. The next is that no matter how much torque our engine makes, the amount of horsepower that it produces is directly dependent on how fast the engine is spinning. Ever wonder how a Honda S2000 can make 230 Horsepower, but less than 200 Ft Lbs. of torque? Well, the early 2.0 Liter S2000’s have a 9,000 rpm redline. If it is spinning that fast, it doesn’t have to produce a lot of torque to make a lot of power. If you plug 230 horsepower and 8,000 rpm’s into the equation above, you should find that you only have to make 150 Ft Lbs. of torque to generate that much power. Now, the flip-side of this is a diesel truck can make 1000 Ft Lbs. of torque, but only makes 500 – 600 horsepower. This is because a typical diesel engine might have a redline of only 3,500 rpm. If you plug in 1,000 Ft Lbs. of torque, and 2,000 rpm’s in to the equation above, you should see that you would only be making about 380 horsepower. Lastly, what this means is that there is no reason that an engine will make its maximum horsepower when it makes maximum torque. So if we want to make more horsepower, we really have two choices. The first is to make more torque at a given rpm. The second is to make our torque curve fall off more slowly, or in other words to make more torque at a higher rpm. And actually, if we could get our engine to make the same amount of torque over a wider rpm range, that would also produce more horsepower. Lastly, to get a sense of how torque and horsepower relate, here are a few comparisons keeping horsepower or torque constant over an rpm range: 200 Hp at 2,500 rpm = 420 Ft Lbs. of torque 200 Hp at 5,000 rpm = 210 Ft Lbs. of torque 200 Hp at 7,500 rpm = 140 Ft Lbs. of torque 200 Hp at 9,000 rpm = 116 Ft Lbs. of torque 200 Ft Lbs. of torque at 2,500 rpm = 95 Hp 200 Ft Lbs. of torque at 5,000 rpm = 190 Hp 200 Ft Lbs. of torque at 7,500 rpm = 285 Hp 200 Ft Lbs. of torque at 9,000 rpm = 342 Hp Link to comment Share on other sites More sharing options...
BagheeraLGT Posted October 4, 2009 Share Posted October 4, 2009 nice response...very insightful Link to comment Share on other sites More sharing options...
specialB Posted October 4, 2009 Share Posted October 4, 2009 that clears things up a lot for me nice work Link to comment Share on other sites More sharing options...
quicklook2 Posted October 4, 2009 Share Posted October 4, 2009 horsepower makes you go fast. torque makes you go fast quicker. Link to comment Share on other sites More sharing options...
blackfang Posted October 4, 2009 Share Posted October 4, 2009 Yep. I have always gone off Torque is how much work the engine can do and horsepower is how fast it can do it. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
Beanboy Posted October 4, 2009 Share Posted October 4, 2009 Yep. I have always gone off Horsepower is how much work the engine can do and torque is how fast it can do it. Don't you mean the opposite? -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
dudeondacouch Posted October 4, 2009 Share Posted October 4, 2009 I hate these discussions. Horsepower is the result of an equation. Nothing more. Torque is the measurement of the power your engine is making. If normal internal combustion engines didn't spin faster than 5000rpm, no one would have even heard of the term "horsepower." True definition of 1 horsepower is the power it takes to raise 33,000lbs 1 foot high in 1 minute. How does that apply to your motor? It doesn't. Heard of a torque wrench? "yup" Heard of a horsepower wrench? "no" /thread Link to comment Share on other sites More sharing options...
E-Tank Posted October 4, 2009 Share Posted October 4, 2009 I hate these discussions. Horsepower is the result of an equation. Nothing more. Torque is the measurement of the power your engine is making. If normal internal combustion engines didn't spin faster than 5000rpm, no one would have even heard of the term "horsepower." True definition of 1 horsepower is the power it takes to raise 33,000lbs 1 foot high in 1 minute. How does that apply to your motor? It doesn't. Heard of a torque wrench? "yup" Heard of a horsepower wrench? "no" /thread Link to comment Share on other sites More sharing options...
dudeondacouch Posted October 5, 2009 Share Posted October 5, 2009 Are you, by any chance, a hot 26 year-old girl? Link to comment Share on other sites More sharing options...
BagheeraLGT Posted October 5, 2009 Share Posted October 5, 2009 so where can i get a horsepower wrench? i think i need one of those to mount my superduper charger Link to comment Share on other sites More sharing options...
blackfang Posted October 5, 2009 Share Posted October 5, 2009 Don't you mean the opposite? mother fer. Yup. I got that one backwards. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
rao Posted October 5, 2009 Share Posted October 5, 2009 I have read that torque is not very important in racing, hence the awesomeness of the RX-8 Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
rockle3 Posted October 5, 2009 Share Posted October 5, 2009 lmao way to bring the debate here rao Link to comment Share on other sites More sharing options...
ehsnils Posted October 5, 2009 Share Posted October 5, 2009 In reality - it's the torque curve that's important. You want it to be wide and relatively flat over a wide rpm range. Below is one for the diesel: http://i42.photobucket.com/albums/e344/dpmiller/curve.jpg And here is one for the GT: http://i96.photobucket.com/albums/l177/ean611/dyno2.jpg Link to comment Share on other sites More sharing options...
rao Posted October 5, 2009 Share Posted October 5, 2009 lmao way to bring the debate here rao I am just bringing knowledge that I learned from this forum to the discussion. If it was true in the other thread then surely it it true here. I also learned that slow cars are faster and fast cars are slower Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
05Boost Posted October 5, 2009 Share Posted October 5, 2009 tourqe puts you in the back of your seat, horsepower keeps you there. Link to comment Share on other sites More sharing options...
ean611 Posted October 5, 2009 Share Posted October 5, 2009 In reality - it's the torque curve that's important. And here is one for the GT: http://i96.photobucket.com/albums/l177/ean611/dyno2.jpg That looks like mine!! Link to comment Share on other sites More sharing options...
MM Legacy Posted October 5, 2009 Share Posted October 5, 2009 COBB has released AccessTuner Race for free! Lets Share some maps! Visit this page at COBB and submit the form with your AccessPort SS# and Cobb will give you the AccessTuner software for Free!!! http://www.cobbtuning.com/info/?id=4431 Link to comment Share on other sites More sharing options...
E-Tank Posted October 5, 2009 Share Posted October 5, 2009 Are you, by any chance, a hot 26 year-old girl? Sorry, broskie. I'm a 24 y/o dood. Though, I do have plenty of girls to spare, but they're mostly in the 18-20 year range. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted October 5, 2009 Share Posted October 5, 2009 Caveat - blatantly borrowed. Horsepower is a measure of the amount of Work the engine does over a given Time. The basic definition of Work is: Work = Force x Distance Therefor: Horsepower = ( Force x Distance ) / Time But what we are talking about here is the relationship between Horsepower and Torque. Torque is basically the force that we are talking about in the above equation. So if we substitute that, and clean things up a bit, what we are left with is the following equation: Horsepower = (Torque X RPM ) / 5252 This actually tells us a lot of interesting things. The first is that at 5252 RPM, an engine’s Horsepower should equal its Torque. I think that you will find that if you look at pretty much any dyno plot of any car, the torque curve and horsepower curve will cross right around 5,200 rpm’s. The next is that no matter how much torque our engine makes, the amount of horsepower that it produces is directly dependent on how fast the engine is spinning. Ever wonder how a Honda S2000 can make 230 Horsepower, but less than 200 Ft Lbs. of torque? Well, the early 2.0 Liter S2000’s have a 9,000 rpm redline. If it is spinning that fast, it doesn’t have to produce a lot of torque to make a lot of power. If you plug 230 horsepower and 8,000 rpm’s into the equation above, you should find that you only have to make 150 Ft Lbs. of torque to generate that much power. Now, the flip-side of this is a diesel truck can make 1000 Ft Lbs. of torque, but only makes 500 – 600 horsepower. This is because a typical diesel engine might have a redline of only 3,500 rpm. If you plug in 1,000 Ft Lbs. of torque, and 2,000 rpm’s in to the equation above, you should see that you would only be making about 380 horsepower. Lastly, what this means is that there is no reason that an engine will make its maximum horsepower when it makes maximum torque. So if we want to make more horsepower, we really have two choices. The first is to make more torque at a given rpm. The second is to make our torque curve fall off more slowly, or in other words to make more torque at a higher rpm. And actually, if we could get our engine to make the same amount of torque over a wider rpm range, that would also produce more horsepower. Lastly, to get a sense of how torque and horsepower relate, here are a few comparisons keeping horsepower or torque constant over an rpm range: 200 Hp at 2,500 rpm = 420 Ft Lbs. of torque 200 Hp at 5,000 rpm = 210 Ft Lbs. of torque 200 Hp at 7,500 rpm = 140 Ft Lbs. of torque 200 Hp at 9,000 rpm = 116 Ft Lbs. of torque 200 Ft Lbs. of torque at 2,500 rpm = 95 Hp 200 Ft Lbs. of torque at 5,000 rpm = 190 Hp 200 Ft Lbs. of torque at 7,500 rpm = 285 Hp 200 Ft Lbs. of torque at 9,000 rpm = 342 Hp Awesome. I've been trying to explain that equation to people for months but nobody around here would understand. That's why diesels have so much torque and so little horsepower. An old saying, Horsepower is how fast you hit the wall... Torque is how far you take the wall with you. Link to comment Share on other sites More sharing options...
johnAWD Posted October 6, 2009 Share Posted October 6, 2009 Regarding dyno plots - this was my supra. http://jsalmi.com/coolimages/dynoplot.jpg Link to comment Share on other sites More sharing options...
Platinum_Racing Posted October 6, 2009 Share Posted October 6, 2009 http://img352.imageshack.us/img352/821/supraresizedfk0.png I found a picture of your Supra! Link to comment Share on other sites More sharing options...
farberio Posted October 6, 2009 Share Posted October 6, 2009 I hate these discussions. Horsepower is the result of an equation. Nothing more. Torque is the measurement of the power your engine is making. If normal internal combustion engines didn't spin faster than 5000rpm, no one would have even heard of the term "horsepower." True definition of 1 horsepower is the power it takes to raise 33,000lbs 1 foot high in 1 minute. How does that apply to your motor? It doesn't. Heard of a torque wrench? "yup" Heard of a horsepower wrench? "no" /thread Torque is a measure of twisting force, so of course a wrench will be a 'torque' wrench and not a horsepower wrench. Horsepower is a measure of (force x distance) / time, so when you turn the wrench you are generating HP. http://www.vettenet.org/torquehp.html Link to comment Share on other sites More sharing options...
DarkLegacy Posted October 6, 2009 Share Posted October 6, 2009 Torque is a measure of twisting force, so of course a wrench will be a 'torque' wrench and not a horsepower wrench. Horsepower is a measure of (force x distance) / time, so when you turn the wrench you are generating HP. http://www.vettenet.org/torquehp.html Link to comment Share on other sites More sharing options...
