ktm200 Posted March 29, 2012 Share Posted March 29, 2012 Dumb question but, I'm getting a 3” bosal v1.5 exhaust to use with the factory 2.5” downpipe, can I simply use one of the 3”DP to 2.5” cat-back adapters flipped backwards from fredbeans? Not having taken apart the exhaust yet, I wasn’t sure if the adapter is directional. Is the collared side of the adapter 3” and supposed to go in the downpipe? THIS is the adapter I was looking at. Link to comment Share on other sites More sharing options...
Nrw Posted March 29, 2012 Share Posted March 29, 2012 You don't need one unless the neck down on the bosal has been removed. Link to comment Share on other sites More sharing options...
ktm200 Posted March 29, 2012 Author Share Posted March 29, 2012 From what I understand, the current owner has the bosal bolted up to an aftermarket DP with no adapter, which makes me think the necked down portion was removed (he is the 2nd owner so it came this way). So I'd like to have the correct adapter incase I need it. Will the above work in the opposite direction (2.5"DP to 3"CBE) or is it directional? Link to comment Share on other sites More sharing options...
ktm200 Posted March 30, 2012 Author Share Posted March 30, 2012 Called around a few places and the above 3"dp to 2.5"cbe will not work in the opposite direction. Anyone know of any places that sell an adapter to go the other way? Link to comment Share on other sites More sharing options...
scoobydoobie Posted March 30, 2012 Share Posted March 30, 2012 You don't need an adapter. You can use the donut gasket/spring bolts with the Bosal. It necks down. Link to comment Share on other sites More sharing options...
iNVAR Posted March 30, 2012 Share Posted March 30, 2012 Ask the seller to send you a picture of the neck. If it tapers down, it'll bolt up fine with the donut. If he had the neck cut off and a 3" flat flange welded on, you'll need to figure something out. Link to comment Share on other sites More sharing options...
ktm200 Posted March 31, 2012 Author Share Posted March 31, 2012 Thanks guys I have a thick flat gasket to make work for now. If that doesn't do it, found that avo sells the adapter to go 2.5"dp to 3" exhaust if anyone else needs the info. Let's you use the donut gasket to. Link to comment Share on other sites More sharing options...
