jerami1981 Posted December 14, 2006 Share Posted December 14, 2006 One of my bolts for my wheels is done for and then some...do i have to replace the hub to get that fixed or are the bolts seperate if i dig deep enough into the assembly, or is it more than just the hub? Link to comment Share on other sites More sharing options...
Boostjunkie Posted December 14, 2006 Share Posted December 14, 2006 First off it's a stud and they are replacable. Spray it down with WD40 or PB Blaster grab a big hammer and whack it out. Slide the replacement in and thread a nut (with the correct diameter and thread pitch) down the stud and the nut will pull the stud in place as it is tightened down. Link to comment Share on other sites More sharing options...
jerami1981 Posted December 14, 2006 Author Share Posted December 14, 2006 first off, thank you for correcting me ...2ndly, i assume it is ok to whack it out while it is still attached to the car. Link to comment Share on other sites More sharing options...
Repsak Posted December 14, 2006 Share Posted December 14, 2006 I know at my chop they sell a hit to get striopped lugs off a car. Its a reverse gripping type of kit. You hammer it on then airgun it off. and yes its just a stud and you can get it replaced. Just put it in a vice hammer it on and hammer the new one back in. [ame=http://www.amazon.com/CTA-Manufacturing-Emergency-Lug-Remover/dp/B0007N201M]Amazon.com: Emergency Lug Nut Remover: Automotive[/ame] something like that will get it out, just find the right size. Link to comment Share on other sites More sharing options...
jerami1981 Posted December 14, 2006 Author Share Posted December 14, 2006 Ahh, sounds great, but i dont have a stripped lug, its a stripped stud.the bolt like piece that the lug screws onto. I managed to get the lug off, though it is done for and it ate the stud on the way off too. Guess in a week or so i'll have another part number for the part numbers list Link to comment Share on other sites More sharing options...
Repsak Posted December 17, 2006 Share Posted December 17, 2006 oh im sorry i mis-read Link to comment Share on other sites More sharing options...
rougeben83 Posted December 17, 2006 Share Posted December 17, 2006 first off, thank you for correcting me ...2ndly, i assume it is ok to whack it out while it is still attached to the car. Yeah, it's ok to wack it while the hub is still on the car. Just don't use like...a 30lb sledge and pretend it's demolishion day. Link to comment Share on other sites More sharing options...
Brady Posted December 17, 2006 Share Posted December 17, 2006 Just don't use like...a 30lb sledge and pretend it's demolishion day. But if you do ... take video and post it here! Link to comment Share on other sites More sharing options...
jerami1981 Posted December 17, 2006 Author Share Posted December 17, 2006 oh im sorry i mis-read Its all good my man. Not so sure i want to demolish my poor car over a stripped stud...but if i do, i'll be sure to vid it and post it up. Link to comment Share on other sites More sharing options...
Andyjo Posted December 18, 2006 Share Posted December 18, 2006 alright... the PROPER way to do this.. you need a custom tool 1) take some hardened steel, throw it in a laythe, and turn it down to about a 3" dia, 1-1.5" thick... make two of those 2) get a 3" OD 1/4" wall pipe, about 6-7" long 4) Weld one end cap on 5) Pour some lead shot into it 6) weld the other cap on 7) weld a handle on... Now you have as we call it an "Answer" it'll fix your stud issues, just a little "Love Tap" should do it Link to comment Share on other sites More sharing options...
jerami1981 Posted December 19, 2006 Author Share Posted December 19, 2006 f it all..i'm just gonna go buy a new car tomorrow and leave this one in the garage forever. Link to comment Share on other sites More sharing options...
