Rester5350 Posted October 5, 2013 Share Posted October 5, 2013 Will 04 sti rear axles work in place of the spec b rears for a r180 swap on a lgt/ obxt? Everything I have read talks about using the spec bs for the swap, I believe they are a little shorter but don't know if it matters much. Thanks in advance. Link to comment Share on other sites More sharing options...
KCwagon Posted October 8, 2013 Share Posted October 8, 2013 Will 04 sti rear axles work in place of the spec b rears for a r180 swap on a lgt/ obxt? Everything I have read talks about using the spec bs for the swap, I believe they are a little shorter but don't know if it matters much. Thanks in advance. STI axles will NOT work. Different length and hub configuration. Link to comment Share on other sites More sharing options...
