SubaruTim Posted November 15, 2010 Share Posted November 15, 2010 Well I plan on buying some wheels over the winter and I found the wheel I want but I want to make sure it will fit without any major modification. The car is at stock height at the moment but I plan on putting on coilovers. http://raderwerks.com/sites/default/files/imagecache/product_full/rw_wheel_mten80bk.png 18x8.0 F / 18x8.0 R 5x100/114 ET38 F / ET38 R or 18x8.0 F / 18x8.0 R 5x100/112 ET35 F / ET35 R 24.0lbs or 18x8.0 F / 18x8.0 R 5x100/112 ET42 F / ET42 R 24.0lbs I'm looking for the most dish I can get out of the wheel. without any rubbing. Any input would be great. It's going on a 2007 2.5i Link to comment Share on other sites More sharing options...
SubaruTim Posted November 15, 2010 Author Share Posted November 15, 2010 Nothing? Link to comment Share on other sites More sharing options...
Underdog Posted November 15, 2010 Share Posted November 15, 2010 Out of three bad choices 18x8 e42 is the least bad. More importantly, what size tire will you be putting on it? Other questions: Why put snow tires on 18's? Why put 24lb wheels on a 2.5i? The Crimson Dynamo Link to comment Share on other sites More sharing options...
Scooter Posted November 15, 2010 Share Posted November 15, 2010 Additional info can be found in the 'sticky' threads, especially Xenonk's: http://legacygt.com/forums/showthread.php/faq-offsets-sizes-rims-and-tires-gt-xenonk-version-4426.html Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
Gire Posted November 15, 2010 Share Posted November 15, 2010 18x8, 38 offset will poke quite a bit, but it has been done before on this forum... Stock offset on the 17x7" rim is +52. Link to comment Share on other sites More sharing options...
SubaruTim Posted November 15, 2010 Author Share Posted November 15, 2010 They would be summer wheels obviously, why not put 24lb wheels on it? It's not a race car just a daily driver. Link to comment Share on other sites More sharing options...
Underdog Posted November 15, 2010 Share Posted November 15, 2010 Stock offset on the 17x7" rim is +52. It's 55mm actually. I misread the OP saying "buying wheels over the winter" as "buying wheels for the winter". Still, light wheels aren't only good for racing, they improve every aspect of driving. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Gire Posted November 15, 2010 Share Posted November 15, 2010 They would be summer wheels obviously, why not put 24lb wheels on it? It's not a race car just a daily driver. Exactly. Do what you want. The OEM wheels aren't exactly light weight forged Volks or anything. And they are much smaller than 18x8. Edit- right. +55mm. Jeez, Subaru really didn't want any rubbing issues with their stock OEM set up, did they? Link to comment Share on other sites More sharing options...
SubaruTim Posted November 15, 2010 Author Share Posted November 15, 2010 How much work do you think I'll need to do for the et38? Just some fender rolling? Link to comment Share on other sites More sharing options...
Gire Posted November 15, 2010 Share Posted November 15, 2010 If you are going to lower it at all, then yes, the rears at least. Link to comment Share on other sites More sharing options...
Drift Motion Posted November 16, 2010 Share Posted November 16, 2010 18x8 +35 <-- offset is not even low enough to play the wheel fitment game try 18x9.5 +38 Link to comment Share on other sites More sharing options...
SubaruTim Posted November 16, 2010 Author Share Posted November 16, 2010 So when i lower the car with the +38 i shouldn't have to do much to make it fit without rubbing. That's good to know. Thanks fellas. Link to comment Share on other sites More sharing options...
Drift Motion Posted November 16, 2010 Share Posted November 16, 2010 Word of advice: Roll your fenders Link to comment Share on other sites More sharing options...
