Ari_OutbackWagon Posted May 29, 2008 Share Posted May 29, 2008 I've noticed lately that I have had a problem getting into reverse. Other gears don't seem as free-flowing as it used to be. Is it possible that having a shorter shifter is wearing something out? What would be worn to cause this issue? Syncro? Bushings? The car has 40k miles. Link to comment Share on other sites More sharing options...
Ari_OutbackWagon Posted May 29, 2008 Author Share Posted May 29, 2008 also wanted to add that i'm using a shifter the same lenght of the kartboy. I have not yet changed the granny fluid, however it's on my list. I should also let you know that it doesn't grind, it just kind of prevents me putting into reverse. Link to comment Share on other sites More sharing options...
croll326 Posted May 29, 2008 Share Posted May 29, 2008 reverse has no synchros - double clutch it you will be fine. Link to comment Share on other sites More sharing options...
nm Posted May 29, 2008 Share Posted May 29, 2008 reverse has no synchros - double clutch it you will be fine. I think he got his car new (or newish), so i suspect this is a new development. However, i'll add that reverse on my transmission has always been a bitch due to the lack of the syncro. Just try pushing the clutch down again or shift into first before you shift into reverse. Link to comment Share on other sites More sharing options...
icrackedcorn Posted May 29, 2008 Share Posted May 29, 2008 i had this problem bad but after a few weeks it stopped being intolerable and a bit later it was totally fine. i duno if i was smashing something loose, building muscle or getting used to it or what obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
Two-Five Sti-L Posted May 29, 2008 Share Posted May 29, 2008 I had the same issues when I installed my Cobb double-adj. STS awhile back, where the base (blue part) was interfering with the rubber surround near the shifter when engaging into reverse. I had trouble getting into R at least 30% of the time. Eventually I reverted back to the stock shifter as I didn't want to risk damage to the tranny. Link to comment Share on other sites More sharing options...
Crawdaddy79 Posted May 29, 2008 Share Posted May 29, 2008 I have a short-throw shifter and sometimes it's impossible to get it into reverse. It's the shifter that is sold by Subaru as an accessory. Link to comment Share on other sites More sharing options...
unlimited6986 Posted May 29, 2008 Share Posted May 29, 2008 Same thing w/ me w/ R. Also shifting for me is alot stiffer since my ss install. I'm prob just gonna go back to stock the shifting is horrible for me. I cant get into 3rd sometimes when the car is cold. Link to comment Share on other sites More sharing options...
Metal2You Posted May 29, 2008 Share Posted May 29, 2008 I adjusted my Cobb STS and it made getting into reverse easier, though it can still be a bitch some times. Link to comment Share on other sites More sharing options...
Voytech Posted May 29, 2008 Share Posted May 29, 2008 Karboy here... No problems whatsoever with getting into 1-5. Reverse won't go in 30% of the time at first try. I usually just put it in another gear and then try again. I wasn't worried about that at all. My old car did the same thing (and that was on the factory shifter). Link to comment Share on other sites More sharing options...
ehsnils Posted May 29, 2008 Share Posted May 29, 2008 I think he got his car new (or newish), so i suspect this is a new development. However, i'll add that reverse on my transmission has always been a bitch due to the lack of the syncro. Just try pushing the clutch down again or shift into first before you shift into reverse. That's mostly a break-in syndrome, older gearboxes almost never have any problems with the reverse - unless you are rolling when you try to throw it in! Link to comment Share on other sites More sharing options...
