Tehnation Posted January 3, 2012 Share Posted January 3, 2012 I have an oil leak somewhere near my turbo. I often smell oil burning, and see smoke from the area where turbo is. It looks like oil is leaking onto the block and getting burned off. But I'm losing a lot of oil, i'm constantly topping it off. Any ideas where the leak is ? Link to comment Share on other sites More sharing options...
joeblow Posted January 3, 2012 Share Posted January 3, 2012 It could be a seal in the turbo going bad. I had the same issue back in August. The turbo won't have any noticeable issues as far as spool and driveability, but oil leaks into the exhaust housing of the turbo and burns off. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
Tehnation Posted January 3, 2012 Author Share Posted January 3, 2012 Could it be repaired or did you need a new turbo? Link to comment Share on other sites More sharing options...
joeblow Posted January 3, 2012 Share Posted January 3, 2012 I had to replace the turbo. As far as I know there isn't really a way to diagnose a leaking seal. It could also be burning somewhere else internally and you just have an exhaust leak at the uppipe or downpipe that allows the burnt oil vapor out. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
Max Capacity Posted January 3, 2012 Share Posted January 3, 2012 check the valve cover gasket, it drips on the up pipe. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
zpolsonGT Posted January 4, 2012 Share Posted January 4, 2012 I've got the same exact smell on the same year and model car. I hope mine isn't the turbo Link to comment Share on other sites More sharing options...
compsurge Posted January 4, 2012 Share Posted January 4, 2012 My guess is the drain hose/line needs to be replaced. http://opposedforces.com/parts/legacy/us_b13/type_12/intake_and_supply_system_turbocharger/turbo_charger/ Check part #12. Part #9 is the infamous banjo bolt (with filter). If it's the oil seal (internal) you may have coolant and oil mixing, mysterious oil and/or coolant loss as a symptom. Link to comment Share on other sites More sharing options...
Tehnation Posted January 5, 2012 Author Share Posted January 5, 2012 I'm going to get a good look after work today, I'll take pictures. Link to comment Share on other sites More sharing options...
