illest Posted January 15, 2014 Share Posted January 15, 2014 Hi LGT Members! So my LGT a.c is randomly turning off and not coming back on. I noticed my CFM (condenser fan motor) not coming on. Should it be on all the time the compressor is on? Or does it cycle on a HPS (High Pressure Switch)? I also feel that when it does work, im not getting its full capacity. I haven't put a set of gauges on it since it only holds a couples of OZ. But i know for a fact is has refrigerant in the system. Any advice is appreciated! Thanks LGT Members! Link to comment Share on other sites More sharing options...
Max Capacity Posted January 15, 2014 Share Posted January 15, 2014 The fans will cycle that's about all I know. I pay the man when I need to. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted January 15, 2014 Share Posted January 15, 2014 Best to check the pressure of the system first. If you're low you can either drain it before filling or top it up. Keep in mind there is a high and low side and respect the pressures on both. Link to comment Share on other sites More sharing options...
FJuan Posted January 15, 2014 Share Posted January 15, 2014 Sounds like you lost pressure in your system. As rob-2 mention, have the pressure checked in the system. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
