kevinlman Posted September 2, 2012 Share Posted September 2, 2012 Hi people, I just built my full exhaust system. I made the mistake of throwing on a "high flow" cat that I had laying around. Now cel has come on (didn't check what code though and have since reset it) and exhaust really stinks. I think its the catalytic converter not being effective since it's a 3" high flow cat. I am now hunting for either a stock catalytic converter or an aftermarket replacement that will work. Does anyone know a cat that will perform as effectively as a stock cat? Or what would be suitable? Which size, model, brand etc. I am on a limited budget. (I haven't priced out a dealer part yet) And I don't want to hack up my stock exhaust in case I need to put it back on for any reason. At the moment I have a WTB thread for an oem cat here http://legacygt.com/forums/showthread.php/wtb-stock-2-5i-catalytic-convertor-192290.html?t=192290 I really don't care about performance or loss of HP from not using a more restrictive/more effective cat. Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 2, 2012 Share Posted September 2, 2012 You put a 3" exhaust on a N/A Legacy? Put the stock exhaust back on. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
kevinlman Posted September 2, 2012 Author Share Posted September 2, 2012 yea. I got a deal for a fms cbe for lgt. unless there's something aftermarket for 2.5i about the same price I would have gone that route. Anyway, that's not the point of this thread. I'm not aiming for HP or anything.. I mean I put UEL headers on the car.. so its purely for the rumble. I already know the pros and cons. I just want some input on whether there is a catalytic converter out there that will perform as well or almost as well as stock. thanks You put a 3" exhaust on a N/A Legacy? Put the stock exhaust back on. Link to comment Share on other sites More sharing options...
Leviman Posted September 3, 2012 Share Posted September 3, 2012 You have an '06. Buy the Vag-com cable and delete the cat code. I mean, er, replace the cat with a functional one! Link to comment Share on other sites More sharing options...
kevinlman Posted September 3, 2012 Author Share Posted September 3, 2012 Right that's what I want to do. I'm just trying to see if anyone has experienced a functional aftermarket alternative. Otherwise I will have to suck it up and go with an oem cat. Thanks You have an '06. Buy the Vag-com cable and delete the cat code. I mean, er, replace the cat with a functional one! Link to comment Share on other sites More sharing options...
freeskierpj Posted September 3, 2012 Share Posted September 3, 2012 He meant use the Vag-com cable to delete the code rather than replacing the cat...at least that's what I think... Link to comment Share on other sites More sharing options...
Berzerklo Posted September 4, 2012 Share Posted September 4, 2012 He meant use the Vag-com cable to delete the code rather than replacing the cat...at least that's what I think... This. Most people fix that problem with a software/ECU change rather than finding an "acceptable" catalytic converter. This should be cheap and easy! Link to comment Share on other sites More sharing options...
05leg2.5 Posted September 4, 2012 Share Posted September 4, 2012 This. Most people fix that problem with a software/ECU change rather than finding an "acceptable" catalytic converter. This should be cheap and easy! So what is the software ecu change? An update or a complete new ecu? And what is the approx. cost? I have the same issues with my 05 Link to comment Share on other sites More sharing options...
whitetiger Posted September 4, 2012 Share Posted September 4, 2012 get a tune, the tuner will be able to disable the code. Link to comment Share on other sites More sharing options...
grovlet Posted September 6, 2012 Share Posted September 6, 2012 It could also be as simple as moving the O2 Sensor back about 1/2". When I put my 2 1/2" exhaust with High Flow Cat on my 98, the shop did say the High Flows sometimes flow to quickly past the rear O2..... I asked how that was fixed, and the answer: Move the O2 back 1/2" or so to account for the additional flow. Link to comment Share on other sites More sharing options...
ruggerheist Posted September 6, 2012 Share Posted September 6, 2012 You put a 3" exhaust on a N/A Legacy? Put the stock exhaust back on. Link to comment Share on other sites More sharing options...
