Pittsburgh 412/724 Turbo Legacy's post up
SPeC.B_MaZTer
Whose from the Burgh?
Watchya whip?
Pix...
Stage/Mods?
Where do you get it tuned?
I'm new to this forum but have been reading it for years as a guest.
My StageII 2k8 Spec.B roams McKeesport/White Oak.
Pix when I can ASAP
Tune= need one ASAP! not sure where to go-NOT driving out of state.
Jason
412 (Munhall[H20 Front]-South hills)
2005 LGT 5MT in SWP (Also 2011 FXT Touring in OBP)
-Stage SL(0)W (AccessPORT on the way!)
-Cobb STS
-Bosal v1.5
-Cusco FSTB
-TRS 6000K HIDs
Like Moore Performance & Race Parts, Great guy.
http://img.tapatalk.com/c6e4c890-bfe2-d671.jpg
Also see here:
http://legacygt.com/forums/showthread.php/new-official-mid-atlantic-member-directory-115241.html
Brilliant Silver 2005 Legacy GT 5MT
-06 WRX complete engine swap ( only 14k on it now)
-FP 68HTA,
-Catless Uppipe
-Invidia Catless DP
-Unknown SS headers
-Perrin Stock Size Intake
-Grimmspeed LWCP
-DeatschWerks 750cc injectors
-GrimmSpeed 8mm Phenolic spacers
-JDM TGV deletes
-Walbro 255
-STI TMIC
-GFB hybrid BOV
-23psi Grimmspeed3 port BCS
-Perrin Mid, Y, and axle back exhaust
-Group N, motor mounts
-Cusco Trans mount
-Kartboy rear Trans mount
-Kartboy short throw shifter
-Whiteline shifter bushings
-Whiteline trans crossmember bushings
-KW V2's w/ Vorshlag camber plates front/ spec B top hats rear
-Sti Brembos
-DS 2500 brake pads
-DBA 4000 rotors
-V7 Sti wheels
-Hankook RS-3 225/45/R17
-TRS bi-xenon HID kit 35w 6000k
-HIR 9011 highbeams
-DDM 35w 3000k HID fogs
-Blackhoused and cleared lights done by IDRVSLO
http://farm8.staticflickr.com/7029/6834246049_0ab0d32073_z.jpg
http://farm9.staticflickr.com/8017/7143745123_937a2c47a4_b.jpg
Moore Performance, TPG Tuning, J's Dyno. All work together.
412LGT
Greentree Area
08 lgt
-stage 2
-forged ej257 swap
-TPG tuned
-STi STS
-Perrin shift bushings
-whiteline rear sway bar
-TGV delete
-EGR delete
-Stage 1 exedy clutch and lwfw
-Racer X FMIC
- Axis Xplode 18x8 wrapped in RS3-S
-Cobb AP
-SPT CBE
-Invidia Catless DP
- Synapse Engineering BOV
Tons of parts sitting at house waiting to get out on. ( up pipe, turbo, etc)
Stay tuned for stage 4 DD
  • 3 weeks later...
Located 40 miles east of the Burgh, Greensburg
2005 RBP LGT limited 5mt wagon
Engine & Exhaust Specifications:
Cobb AP Stg 1 93oct
Grimmspeed SS uppipe
SPT CBE wagon fitment
Drivetrain:
OEM WRX clutch & single mass flywheel
Suspension:
Koni adjustable struts f&r
iON HD springs wagon fitment
Cobb f&r sway bars
Cobb rear sway stout mounts
Kartboy solid rear endlinks
Brakes:
Hawk HPS pads f&r
Centric premium rotors
Wheels:
Rota Tarmac II, 18x7.5, +48, silver metallic with 225/40 Kumho LE sports
'04 STi BBS, 17x7.5, +53, black metallic with 225/45 Winterforce Extremes
Interior:
OEM all weather mats
STi duracon 5mt shift knob
Exterior:
RBP color matched OEM grille
RA black/grey mudflaps
Muteki SR35 black closed lugs
'STi' center cap overlays on Rota Tarmac II
Thule bike/ski carrier
724 Washington, PA
Block:
Manley Platinum Series Pistons 99.75
Manley H Beam Connecting Rods
Nitrided Crank
11mm Oil Pump
ACL Race Main Bearings
ACL Rod Bearings - Extra Oil Clearance
TGV Deletes
KillerB Pickup / Windage Tray / Pan
GrimmSpeed AOS
Perrin LWP
Subaru OEM Gasket Kit
Heads/Plugs:
GSC Stage 1 Cams
Manley Extreme Duty Exhaust Valves 32mm
Manley Race Flo Intake Valves 37mm
Manley Valve Spring and Retainer Kit
Valve Job
ARP Head Stud Kit
NGK Iridium One Step Colder Spark Plugs
Turbo/Exhaust:
AVO380 Turbo
Cobb Catted Down Pipe
IAG Up Pipe / Tial 38mm External Waste Gate (EWG Routed to DP)
Agency Power ELH
Exhaust Wrapped Header / Downpipe / Uppipe
SPT Cat Back
Intake:
IAG Custom Big MAF
AVO Cold Airbox
AVO Silicone Inlet
Process West TMIC
Fuel:
Cobb Spec DW850cc side feed
AVO 245lph Fuel Pump
Engine Management / Tune:
Cobb AccessPort
Tune by Jorge Carrillo
Meth:
Labonte Water/Meth Kit
AEM 30-3020 Fail Safe
Snow SafeInjection
Other:
Gates Racing Power Steering / Alternator Belt
Gates Racing Timing Belt
Gates Water Pump
Fumoto Oil Drain
SPT Engine Mounts
SPT Pitch Stop
Brakes:
Stoptech Street Performance Brake Pads Series 309
Goodrich Stainless Steel Brake Lines
Suspension:
Rallitek Sport Springs Legacy GT & Spec B 2005-2009
Koni Subaru Legacy GT Sport Absorbers – Externally Adjustable
Whiteline Front Roll Center Adjustment Kit
Whiteline Steering Rack Bushing Kit
Whiteline Front Inner Control Arm Bushing Kit
Whiteline Camber Adjustment Kit
Whiteline Anti Lift/Caster Kit
Perrin 22mm Front Sway Bar
Perrin 22mm Rear Sway Bar
IAG Performance Alignment
Whiteline Rear Differential Mount Inserts
Transmission:
High Performance Transmission – Extra 4th & 5th Gear Clutches Added
Custom Valve Body Modification (specially Transgo customized 350Z Shift Kit)
Tru-Cool LPD Auxiliary Transmission Cooler
Wheels/Tires:
Yokohama S Drive 235 40 R17
Rota G-Force (5x100/e48/56.1)
Motegi Tuner Spline Lug Nuts
Interior:
Prosport Premium Boost Gauge
Prosport Premium Oil Pressure Gauge
Cubby Mount Gauge Pod
Momo Race AirLeather Shift Knob
Diode Dynamics LED Map Lights, Door Lights, Dome Light, and Trunk Light
Redline Shift Boot / Redline Emergency Brake Boot
Satechi Soundfly SD WMA/MP3 Player Car Fm Transmitter (JDM on the way!)
Dual OEM Subwoofers
Escort Passport 8500 X50 Red, BlendMount, and InvisiCord
JDM Aluminum Pedal Set – Automatic Transmission
Prosport Aluminum Dead Pedal
Exterior:
Debadged
JDM Grille / GrilleGuy Razr Grille
Osram H7 Rallye+65 Low Beams
Toshiba HIR 9011 High Beams
R-Rev Extended Scoop
R-Rev Eyelids
R-Rev Type S Spoiler
RavSpec Front Lip (currently in R&R)
I probably forgot a few things too. :lol:
Went w/ a conservative tune since this is a DD. 337whp was the final. Was pretty hot though, think it was like 82 degrees and Jorge said it was heat soaking. Plus its a 5EAT.
Once I get some more miles on the motor probably going to swap out the turbo with something like a Dominator 1.5xt-r, 2.5xt-r, or a Garrett gtx3071r. Want to get around 375whp and still have decent spool. Already have the additional hose for the Process West so I am not limited to LGT fitment for the turbo.
