Moderators BarManBean Posted July 7, 2014 Moderators Share Posted July 7, 2014 Anyone running a tactrix as a standalone logger? I'd like to get mine setup so I can just keep it plugged into the OBD port and have it log pretty much all the time. Gonna do some googling, but any help would be appreciated! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
rhino6303 Posted July 7, 2014 Share Posted July 7, 2014 I have attached one from my 2005 LGT with the A2WC522N ecu. The file is in an excel so that I could attach it. Just copy the entire column A and paste it into a text file. I have pretty much every parameter ever needed and it is set to log when the RPM is above 0 and the coolant temperature is above 150 degrees F. This is also set up to log my LC-1 which is attached to the openport. The ; is used on lines that aren't utilized (this way I am not logging everything all of the time). I tried to get a condition so that I could turn on the defroster and create a new file when I wanted but it never worked as planned. Sorry for the long response.logcfg.csv Link to comment Share on other sites More sharing options...
rhino6303 Posted July 7, 2014 Share Posted July 7, 2014 Here is a good thread to reference. Another thread here that has a link to a useful web based program if you are using a different ecu than what I posted. One more here that allows you to use your romraider logger file to create a logcfg text file. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 7, 2014 Author Moderators Share Posted July 7, 2014 Awesome, I'll look into all of that, thanks! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted July 8, 2014 Share Posted July 8, 2014 http://legacygt.com/forums/showthread.php/standalone-logging-microsd-w-opv2-0-134306.html?t=134306&highlight=standalone ^^great info. Be aware(beware?) that the logging speed is split among the parameters. I suggest avoiding the 4 byte ones if possible. I was able to get 6-7 lines a second with the log in post #87. Use more 1 byte(databits=8) parameters and split the temps or things that change slowly with the "sampgroup" option. Link to comment Share on other sites More sharing options...
