Timing Belt Replacement Cost?
Plan on $1000.00 maybe $750 from a independant shop....call one and ask. I spent about $525 on parts alone when I did mine 2 years ago.
Engine Build - Click Here
$400 would be considered a good deal for labor. $500 is probably closer to average. The cost of parts will vary depending on what you need to replace. You will at least need a new belt (obviously), a new tensioner, and the small pulley next to the tensioner. If the water pump is leaking you will need a new one of those.
Fredbeans parts has all the replacement parts you may need in one, nice & neat package. You might check it out.
Average range should be $750-$900 depending on shop rate and parts needed.
Might as well do the 2 drive belts (PS & Alt) and change the anti-freeze. Thermostat ?
It all adds up. May be close to a oil change too.
