Creator1322 Posted May 2, 2012 Share Posted May 2, 2012 I'm looking for the torque specifications for the following items relative to the image linked/attached to this post: Nut #1 (Attached to #5) & Nut #4 If you're familiar with any instructions relative to replacing #5, I would appreciate it. The passenger side bushing of #5 is leaking badly. It's a very "gooey" substance and is "stringy" when pulled apart between fingers. Interesting to say the least. Thank you very much! I have a 2006 Outback XT Limited, same chassis as Legacy as referenced using the link below. Link to the actual page: http://opposedforces.com/parts/legacy/us_b13/type_45/train/differential_mounting/ http://static.opposedforces.com/epc_img/366495141501.png Link to comment Share on other sites More sharing options...
whitetiger Posted May 2, 2012 Share Posted May 2, 2012 Just make sure its nice and tight. Tq spec isn't critical here. I'm sure someone will chime in with a number if you insist. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 2, 2012 Share Posted May 2, 2012 When I did pulled my rear diff twice last summer. I just tighten them up good and tight. Don't about the small stuff. Some things are important to be torqued, this is not one of them. I'll pm a link that will give you all the info on the car you need. they don't like us to post it on the forum. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Creator1322 Posted May 9, 2012 Author Share Posted May 9, 2012 Took it to my local repair shop and it took 20 minutes and $50 cash. There was a small tear in the front passenger side bushing which caused a leak requiring this replacement. Thanks for the assistance everyone. Link to comment Share on other sites More sharing options...
