rojo412 Posted October 25, 2011 Share Posted October 25, 2011 I was getting some "clunks" in my 98 Legacy GT wagon that were very random. Didn't think much of it... until yesterday. As I was driving along, I noticed that the noise was coming every time I'd accelerate OR when I let my foot off of the gas pedal (auto trans, btw). Also, when I was coasting along, I started to hear some squeaking/squealing. The braking didn't have an effect on the noise, so I was assuming the issue was related to either suspension or a mount of some sort. If I hit a bump, it wasn't making any sort of odd noise just at that moment (like a ball joint or bad rattle from a bunk bushing). It seemed related mostly to the torque from the engine/trans/etc. Is there anything jumping out to the tech-minded people reading this? If I do go looking for problem spots, any suggestions where to start or what to look for? 120k on the car, AT, Legacy GT. Any help is MUCH appreciated. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 25, 2011 I Donated Share Posted October 25, 2011 First thing I would look at is both motor mounts and transmission mount -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
rojo412 Posted October 26, 2011 Author Share Posted October 26, 2011 I will definitely do that. In the mean time, last night's commute had this happening: As I'd accelerate, I could feel the shake, but when I let off the gas, it would "chirp" repeatedly, as if a bearing was having issues. Link to comment Share on other sites More sharing options...
bushey45 Posted October 26, 2011 Share Posted October 26, 2011 Sounds like a universal joint to me. Get under the car and see of there is excessive play in the drive shaft. If there is then its a universal joint. The bad part is I believe you have to change the whole drive shaft instead of just the u joint. Link to comment Share on other sites More sharing options...
