BigTDogg MA Posted September 12, 2011 Share Posted September 12, 2011 I wanted to start this thread rather than hijacking INVAR's even though it's the same topic. So here's the deal: 2005 LGT 5MT 107000 miles Catless STI UP with EGT bung custom welded in. Cobb catted DP Apex'i dry panel filter. Stock tune I haven't got tuned yet, but pulled some screenshots before clearing my CEL. A P0420 is normal for a 05 with a catless UP, right? These are taken in chronological order. My IAM stays at 1, and I have no red in the cells, so I just want to be sure this LV is reading and working correctly. I got on it a bit in a tunnel, and could have sworn I heard some pinging, but everything looks clean . By "get on it" I mean gave it about 50% throttle from 2500 to 4000 RPM. I still don't want to go boom, but I want to see if it's detecting knock correctly. Link to comment Share on other sites More sharing options...
Ridgeracer Posted September 12, 2011 Share Posted September 12, 2011 Looks good so far. How many miles now total driving since the reset? Fuel trims take a good amount of mixed driving to settle in. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
BigTDogg MA Posted September 12, 2011 Author Share Posted September 12, 2011 Oh, I reset almost every day because my P0420 comes back. Maybe I should just run with the CEL on for a bit. Does tripping that particular CEL affect my fuel/timing maps? Link to comment Share on other sites More sharing options...
iNVAR Posted September 12, 2011 Share Posted September 12, 2011 Thanks for not hijacking. You're on a stock tune but with stage 2 hardware. You should not be getting on the throttle till you're tuned appropriately. P.S. You just reminded me to update my LV, thanks. Link to comment Share on other sites More sharing options...
Ridgeracer Posted September 12, 2011 Share Posted September 12, 2011 Resetting the ECU every day doesn't really help paint a clear picture...Get a stage 2 map from a trusted tuner and start data logging. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
BigTDogg MA Posted September 12, 2011 Author Share Posted September 12, 2011 Waiting on my Infamous tune. I paid on 9/2, still waiting for anykind of confirmation, let alone a tune. If I don't get something by Thursday I'm canceling and going local. Link to comment Share on other sites More sharing options...
MasAyinde Posted September 12, 2011 Share Posted September 12, 2011 I thought you were going to go with a temp Stage 2 until you heard from Infamous? Link to comment Share on other sites More sharing options...
BigTDogg MA Posted September 12, 2011 Author Share Posted September 12, 2011 I thought you were going to go with a temp Stage 2 until you heard from Infamous? I'm a pussy I don't want to mess with stuff in the hex file and go boom. My IC isn't reinforced yet either. I'm most likely going to cancel and go with a local guy who doesn't have as many clients to manage. I'm sure Infamous is good, probably even great and all, but he should hire a hot college chick to handle his customer service. Link to comment Share on other sites More sharing options...
MasAyinde Posted September 12, 2011 Share Posted September 12, 2011 or take on less work and deliver customer service to existing clients. This has been discussed at length. There isn't enough or a market to just tune LGTs as a full time job and make ends meet. he does it as a side gig and who knows how busy he is with his other job. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted September 12, 2011 Author Share Posted September 12, 2011 This has been discussed at length. There isn't enough or a market to just tune LGTs as a full time job and make ends meet. he does it as a side gig and who knows how busy he is with his other job. Understandable, but AFAIK, he also does other Subies. He could take the first 30 minutes of his afterwork time and bang out one line emails to clients. Just sayin. Link to comment Share on other sites More sharing options...
scoobydoobie Posted September 13, 2011 Share Posted September 13, 2011 This has been discussed at length. There isn't enough or a market to just tune LGTs as a full time job and make ends meet. he does it as a side gig and who knows how busy he is with his other job. Also been discussed that tuning IS his full time job/only job now. He tunes a lot more cars than just LGTs... Link to comment Share on other sites More sharing options...
bmx045 Posted September 14, 2011 Share Posted September 14, 2011 His laptop went down, and apparently it must be the only way to access email. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted May 4, 2012 Author Share Posted May 4, 2012 So this is the LV I pulled this morning. CEL on with flashing cruise. I'm not sure if it was caused by a faulty remote start (cranked for 3 seconds but didn't fire, automatically tried again 15 seconds later and fired right up), but it drove fine. Reset the code after pulling this, tried to do a log but it didn't record. Kinda like the time I hit that hole in one on a par 5 So thoughts? Link to comment Share on other sites More sharing options...
bmx045 Posted May 4, 2012 Share Posted May 4, 2012 big air leak at idle. recommend a boost leak test. the air leak is bad enough that the cyl is misfiring(due to lean unmetered air entry)could be intake manifold gasket or something else. quickest and easiest way to pinpoint where the problem is is to BL test it and listen for where the air hisses out. Berto can do this for you too. other than that the rest of it looks fine. but it's pretty clear that it's an issue only at idle. + a/f correction numbers indicate the ECU has learned to add fuel since the A/F's are not in target range, adding fuel would mean that you are running leaner than before, thus an unmetered air entry to the system. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted May 4, 2012 Author Share Posted May 4, 2012 Thanks, you happen to know the ID of the intake hose? I have a BLT for my Z, but I don't think they're the same ID. I've got a week before I see 'Berto, so I'd like to check it out ASAP. Link to comment Share on other sites More sharing options...
bmx045 Posted May 4, 2012 Share Posted May 4, 2012 the inlet is, if i recall correctly, 2 1/4". you can go to home depository and find a pcv cap, tap a hose air fitting into it, a cylindrical spacer, and a black rubber reducer to stretch over the inlet, clamp em tight, and pressurize! literally, any way possible to fit a bike hose or air tool hose fitting sealed to the inlet, air tight, is all you need. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted May 4, 2012 Author Share Posted May 4, 2012 I already have one of these: http://www.boostpro.net/images/tester2.jpg So I just need to make an adapter to the ID of the LGT intake. I may do that this weekend. 5 PSI a good limit for BLT on LGT? Link to comment Share on other sites More sharing options...
bmx045 Posted May 4, 2012 Share Posted May 4, 2012 supreme. fwiw, i pressurize to 5-10psi and then let the needle drop and listen. IMO no need to jack the psi to boost levels. You'll hear the check valve(i think?) piece buzz while building pressure, it'll go away as you keep pressurizing. you can always plug some ports if you want but imo, leaving the system as is is the best way to determine leaks in the vac lines/manifold lines, just don't pressurize it too high as it put positive crankcase pressure in the case and the oil seals do not like that. leave the oil fill cap on but be weary of what pressure you're putting in the system Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted May 4, 2012 Moderators Share Posted May 4, 2012 Bmx is suddenly in every thread...love it! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
GTTuner Posted May 4, 2012 Share Posted May 4, 2012 Clean the MAF, make sure the o ring is ok on the MAF sensor. I was getting a stumble off idle and found the o ring on the MAF sensor was split, letting air in. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted May 4, 2012 Author Share Posted May 4, 2012 Will do, thanks guys. Link to comment Share on other sites More sharing options...
hadvw Posted May 5, 2012 Share Posted May 5, 2012 Sorry for the thread jack (you may have have also seen this in the BNR thread). Some comments on this LV output please? '05 LGT 5EAT, bnr16g, injectors, fuel, APv1 tune. Bad idle/stumble/stalling at times. Am going to look at MAF next, and maybe clean battery terminals if they need it.. Link to comment Share on other sites More sharing options...
rtbrjason Posted May 5, 2012 Share Posted May 5, 2012 Sorry for the thread jack (you may have have also seen this in the BNR thread). Some comments on this LV output please? '05 LGT 5EAT, bnr16g, injectors, fuel, APv1 tune. Bad idle/stumble/stalling at times. Am going to look at MAF next, and maybe clean battery terminals if they need it.. Did this just start? Did you get gas someplace new? Looks similar to what I saw the one time I filled up with bad or mis-marked 93 octane. Link to comment Share on other sites More sharing options...
iNVAR Posted May 5, 2012 Share Posted May 5, 2012 Looking at the other thread, your have a BNR16G... and I'm assuming the Stage 2 supporting mods? (DP, UP)? If so, I'm wondering why your tuner didn't rescale the learning tables. A final column of 1.60+ really doesn't tell us a whole lot and covers a pretty huuuuuuuuge range. A typical stage 2 doing about 18PSI will have a cap of about 3 load, sometimes going higher in cold temperatures, as high as 3.20. edit: Just realized that the above doesn't really help a whole lot with your idle/stall issues, but still somewhat important to know. You have learned knock all over the place that would be worth looking into. Link to comment Share on other sites More sharing options...
hadvw Posted May 5, 2012 Share Posted May 5, 2012 Did this just start? Did you get gas someplace new? Looks similar to what I saw the one time I filled up with bad or mis-marked 93 octane. Today is the first time I have done any logging. I have run this tune for just over 2 years on a bnr16g, gutted up/dp, 650cc injectors, walbro. Everything else stock (TMIC, intake, etc). We only get 91 here in CA, but the car was tuned for that. Link to comment Share on other sites More sharing options...
