05wagongt Posted February 23, 2013 Share Posted February 23, 2013 i have the bolt to plug my bung, and a lock washer... do i have to remive the uppipe to got to the sensor, or can it stay on the car? i see it poking out from the turbo heatshield, but wasnt sure if its easy to access? if so, how do i get to it? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 23, 2013 Share Posted February 23, 2013 Guessing you have a catless up pipe on the car already ? Most level it in the old up pipe, you should be able to get it out with a wrench and some PB Blaster. Do you have the 2.2k ohm resistor to defeat the CEL ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
05wagongt Posted February 24, 2013 Author Share Posted February 24, 2013 yep, went and boutht hem yesterday, and the bolt to fit the bung, took old pipe into store and made sure i could get the bolt to fit. do i hyave to take off the heatshield? or can i do it with it on? just asking so i can figure out how much time i need to do this Link to comment Share on other sites More sharing options...
05wagongt Posted February 24, 2013 Author Share Posted February 24, 2013 and yes, i have the invidia one on already Link to comment Share on other sites More sharing options...
