NE.PA Posted June 22, 2012 Share Posted June 22, 2012 My 2005's hood won't shut flush. I removed the hood portion of the latch and it closes almost perfectly. Does anyone know of other adjustments? Link to comment Share on other sites More sharing options...
lee07 Posted June 22, 2012 Share Posted June 22, 2012 In a accident? Got tools laying around the corners of the engine? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 22, 2012 Share Posted June 22, 2012 I think what your asking is, how to raise the latch ? Remove the grill, then loosen the bolts that hold the latch, slide the latch up, tighten the bolts, install the grill. Be careful pulling the grill out, there are bottom clip things that can break off. Use a small screw driver to push the release in the top clips. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
