D_Sp8s Posted October 15, 2015 Share Posted October 15, 2015 Hi All, I was hoping someone might be able to help me out with a problem on my stock 2005 LGT. In the past few weeks, whenever I try to start the car, the starter will crank the engine over and over, but it won't start....until I floor the gas pedal, then it'll take a few more turns and it will start up. When it does this, I usually see a nice spew of white smoke from the tail pipe. I've checked the air intake for blockages, cleaned the air filter, cleaned the MAF. There hasn't been any CEL codes yet. Anyone have a suggestion what to check next?? Thanks! Link to comment Share on other sites More sharing options...
quick4dr Posted October 16, 2015 Share Posted October 16, 2015 fuel pump Link to comment Share on other sites More sharing options...
Harsho1 Posted October 16, 2015 Share Posted October 16, 2015 These are throttle by wire cars. Holding down the pedal will close the throttle plate all the way to put it in flooded mode. you may have injector leakdown. Smell the white smoke if you can, if it is sweet smelling you have a coolant leak into the combustion chamber. Link to comment Share on other sites More sharing options...
D_Sp8s Posted October 17, 2015 Author Share Posted October 17, 2015 fuel pump Any advice on how to confirm it is, in fact, the fuel pump? These are throttle by wire cars. Holding down the pedal will close the throttle plate all the way to put it in flooded mode. you may have injector leakdown. Smell the white smoke if you can, if it is sweet smelling you have a coolant leak into the combustion chamber. Thanks for the help. Can you elaborate a little on what you mean by injector leakdown? Also, would a coolant leak into the combustion chamber be due to a bad head gasket? Link to comment Share on other sites More sharing options...
ehsnils Posted October 17, 2015 Share Posted October 17, 2015 Also check for leaks in the manifold, like bad donut gaskets, cracked/broken hoses, bad PCV valve. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 17, 2015 Share Posted October 17, 2015 http://people.csail.mit.edu/ilh/vacation/ That may help to. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
