98legwag's 2009 3.0R Limited
98legwag
I bought this car back in September 2013. My previous car, which I still have, is a 1998 Legacy L wagon. It got me hooked.
Interior:
LEDs in map/dome/trunk/door lights
All weather floor mats
45% tint on sides and rear winshield
Liberal Albero carbon fiber shift knob
10 inch Polk Audio sub in a Wicked CAS Magic box to replace blown factory Harmon Kardon sub
IAG floor mat bracket
Exterior:
LED tag lights
Hella Sharp Tones
DDM Tuning Plus HID kit 35 watt 4500K
Osram Night Breaker Unlimited fog lights
Narva Range Power +50 high beams
RREV LED reverse lights
Silver/chrome coated amber rear turn signal bulbs
Vinyl overlays on front and rear emblems
Bayson R lip
Engine, exhaust & Trans:
AEM Dryflow drop in panel filter
HKS ES Premium axle back
Subaru OEM Battery Cover
Subaru OEM Power Steering Cover
Suspension, chassis, brakes, & Handling:
Grimmspeed Brake Master Cylinder Brace
Matte black painted calipers
Hawk HPS brake pads
Tribeca 25mm front sway bar with Energy Suspension bushings
JDM 20mm rear sway bar with AVO polyurethane rsb bushings
AVO reinforced rsb mounts
Perrin front and rear endlinks
Cusco front strut tower brace
Cusco rear strut tower brace
Mevotech aluminium LCAs
Wheels & tires:
BBS RV723 (04 STI) 17x7.5 +53 wrapped in 235/45/17 General G-Max AS-05
Stock wheels 18x7 et55 currently wrapped in 215/45/18 Pirelli P Zero Nero M+S
  • Replies 166
I would have loved to have found that exact car when I was shopping for my project vehicle. It's my favorite model in my favorite car color. I will be following this to see what you will do to it. Congrats on a wonderful find.
2010 2.5GT limited is for sale. :)
Its good. I bought it about a year ago. Next on my list is take the door cards off and put something on them to stop the rattling. Other than it will probably stay how it is for a while. It does have a slightly warped rotor on the right front from the previous owner. I will put new rotors on the front when it needs pads.
I don't know where in MD you are but I would be willing to help out another 3.0R :)
Thanks. I am in Gaithersburg. Right now I am dealing with a blown factory HK sub. I am trying to decide if I want to take my friend's 10in sub and box and run the wiring from the stock sub to that in the trunk or put something were the stock sub is.
Your LED's look really REALLY white in the pics. Where did you get them? And in person do they have a bluish hue?
I got them from superbrightleds.com. They are the "cool white" color. I think they look really white in person as well as in the pictures.
For those who don't know, the factory HK sub in my car blew a few weeks ago. I got a 10 inch sub and box from a friend on Friday. The box was originally a box for 2 10inch subs that she cut in half and put the other one in her CRX.
Oh, and I also ordered my next performance mod. Nothing too crazy, but it should be here Wednesday.
So today a big box arrived....
http://i1098.photobucket.com/albums/g378/98legwag/2009%20%20Legacy%20R/20141119_170340_zps8xtpq1oj.jpg
If you guess it contains a Tribeca front sway bar then you would be correct.
http://i1098.photobucket.com/albums/g378/98legwag/2009%20%20Legacy%20R/20141119_173847_zpsmcmhpi5l.jpg
That's one weird mod. How is it different to the stock one?
Its 4mm bigger. Its 25mm while the stock 3.0R fsb is 21mm. But I have read that due to its shape and the fact it curves over the tie rods, not under like the factory and aftermarket Legacy bars, it will essentially feel like a 23mm bar. Plus there aren't many available NA Legacy aftermarket front sway bars out there. And this is much cheaper than those that are available.
Well, the Tribeca front sway bar is installed with the help of a friend. Went a little differently than I thought. After putting the car on ramps to disconnect the end links and unbolt the stock sway bar we jacked the car up and put it on jack stands to remove the stock sway bar. Then we noticed the headers on the H6 are thicker than the headers on the NA 4 cyl cars. This meant the headers had to be unbolted from the heads to get the stock sway bar out and get the Tribeca bar in.
The bushings where slightly loose so we wrapped plastic around the bar then put the bushings on that. The bushings I used are part # 9.5161R. Here are pics of the Tribeca bar resting "in place" while the Energy Suspension bushings are being put on as well as some of the bushings and ES brackets.
The next thing we noticed was after taking the car off the jack stands and putting it back on the ramps was that the new sway bar was lining up directly over the end links. We solved this problem by spacing the end links in slightly from the control arms. We did this with a nut slightly bigger than the end link bolts. I should add the hardware supplied with my Perrin end links is shouldered bolts so the nut used a spacer had to fit over that shoulder. Here a couple pictures showing that.
The next thing we noticed was the bolt hole in the sway bar itself is larger than that on the stock sway bar, end links, and bolt itself. I did not want any clunking. We used brass "specialty washers" from Loews Hardware to fix the problem. We cut one in half and put a half on each bolt holding the sway bar to the end links. The brass washer was slightly larger than the sway bar hole, but is compressed down. My friend had used the Dremel to taper one end of the brass washer/sleeve. Here are pictures of what we used and the process of bolting the sway bar to end link and crushing down the brass sleeve.
In this one you can see the brass sleeve on the bolt just next to the head of the bolt outside of the sway bar. The second picture shows it a little crushed/tightened down.
1907981_10205340152413508_8368083951037093512_n.jpg.32c902bce90641d2b134b1b46e2926f3.jpg
10393763_10205340157773642_2280235297282982277_n.jpg.4d79f5f578db9926e8fd1f5cae6d77e4.jpg
10383542_10205340159493685_3485655142512809397_n.jpg.75a70410f8c793eb67e74a5eea3d5db7.jpg
10429352_10205340160053699_7335354963477347743_n.jpg.5fa26c135fd887da180bec385d8d20a6.jpg
10460708_10205340157813643_1957844883681874148_n.jpg.21c5f911f4dfb20b22a056be0a689d9f.jpg
  • 2 months later...
I just finished up installing the brace. It was much easier than the one on the wagon. Only hard part tonight was threading in the bottom bolt on this. On the 3.0R that hole in the strut wall was not used so it had a rubber tape over it that needed to be pierced.
