crazychristopheo Posted May 17, 2009 Share Posted May 17, 2009 I don't have the luxury of GPS in my legacy so I have decided to upgrade soon. How will this be done since there is a whole panel that holds the Ac dials and radio controls? Do I perhaps use the little compartment above my radio ? Also does installing an aftermarket stereo delete the controls in the bottom panel ? How would a dash kit work ? Single Din or 2 DIn Link to comment Share on other sites More sharing options...
drsnobiz Posted May 24, 2009 Share Posted May 24, 2009 There's tons of information in this section if you search around and look for it. What you're speaking of is possible but difficult. You should begin by looking at the 05 LGT Audio FAQ sticky. Link to comment Share on other sites More sharing options...
zmarko Posted May 24, 2009 Share Posted May 24, 2009 AVO din. Search ^ that. Link to comment Share on other sites More sharing options...
JonLGT Posted May 24, 2009 Share Posted May 24, 2009 I took a USDM nav din and hacked it up. Link to comment Share on other sites More sharing options...
crazychristopheo Posted May 24, 2009 Author Share Posted May 24, 2009 Is this procedure something you would be willing to repeat ? Link to comment Share on other sites More sharing options...
crazychristopheo Posted May 24, 2009 Author Share Posted May 24, 2009 Actually let me rephrase that, "Is this procedure something that has a writeup behind it ?". I would definitely devote many man hours to this cause. Link to comment Share on other sites More sharing options...
BLACKSUBIE206 Posted May 25, 2009 Share Posted May 25, 2009 there is adapters that take the stereo part out and leave ur climate control untouched look up adapters u can go to car toys and they will show u a pic Link to comment Share on other sites More sharing options...
zmarko Posted May 25, 2009 Share Posted May 25, 2009 there is adapters that take the stereo part out and leave ur climate control untouched look up adapters u can go to car toys and they will show u a pic Huh? Link to comment Share on other sites More sharing options...
biz77 Posted May 26, 2009 Share Posted May 26, 2009 there is adapters that take the stereo part out and leave ur climate control untouched look up adapters u can go to car toys and they will show u a pic <facepalm> Let's see 'em! Link to comment Share on other sites More sharing options...
crazychristopheo Posted May 26, 2009 Author Share Posted May 26, 2009 ^+1 Link to comment Share on other sites More sharing options...
LLBean Posted May 9, 2010 Share Posted May 9, 2010 http://www.mediafire.com/file/gmijybfetgm/Subaru Legacy.pdf Link to comment Share on other sites More sharing options...
zmarko Posted May 10, 2010 Share Posted May 10, 2010 http://www.mediafire.com/file/gmijybfetgm/Subaru Legacy.pdf Are you just bumping any thread with aftermarket stereo in it with your link? I just finished saying in another thread that there is a MUCH easier way to get a dual din aftermarket stereo into an LGT than your method. I'd hate to see someone who doesn't have the talent that you do go through what you did when they could have EASILY purchased a kit for $300 that would enable them to install an aftermarket stereo into their LGT. Now, while $300 may seem like a lot to some, the amount of time it would take to undertake what you did is probably in the 15-20 hr range. Again, I know you're proud of your achievement. But I don't think many here have the ability you do when it comes to it. Link to comment Share on other sites More sharing options...
LLBean Posted May 10, 2010 Share Posted May 10, 2010 Was just trying to get the word out - I have been slammed already for spamming the forum - this was not my intent. I have done alot of research on this issue and found no detailed doumentation to follow, so I wanted readers who did want to take part in this activity a road map in how to do it. I can easily spend the $300 for the kit, but I have a higher expectation in the fit and finish that solution offers. Others may or may not agree. Peace. Link to comment Share on other sites More sharing options...
Swiss1 Posted December 10, 2010 Share Posted December 10, 2010 Holy ..... That seems a very risky solution. Been researching stereos and narrowed it down to a couple, then was going to check out how easy it is to replace the in-built unit (decided to check on-line instead of pulling it apart myself). Basically not something that can be easily done. So will check out the other option of using the empty space above the main facia where a Nav unit can be installed. Link to comment Share on other sites More sharing options...
