Gravedigger Posted September 28, 2008 Share Posted September 28, 2008 I have had my car in the shop for 3 weeks. I finally got all the parts in I needed but the AVO 420 install is not working. The banjo bolt does not fit and the air inlet pipe is too small to fit on the new turbo. I thought this was a bolt on deal. I am missing something? I have a perrin top mount intercooler and Cobb up and down pipe with stock intake manifold.I really need to get this car back together. Shawn Cell 423-280-0442 if you have any suggestions I would appreciate it. This is my daily driver. Link to comment Share on other sites More sharing options...
PhilT Posted September 28, 2008 Share Posted September 28, 2008 The air inlet will fit, but you have to stretch it over, be gentle they have been know to rip. I had the same problem with the oil inlet line, they sent me the wrong flex line. I opened up the hole in the banjo fitting of the OEM pipe to fit the new banjo bolt. They did send you a larger banjo bolt ? Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Gravedigger Posted September 28, 2008 Author Share Posted September 28, 2008 I got the turbo used from a guy on this forum. It did not have a larger banjo bolt. Is this something that can be ordered quickly or picked up spmewhere locally you think? Link to comment Share on other sites More sharing options...
PhilT Posted September 28, 2008 Share Posted September 28, 2008 I would give the guy you bought the turbo from a call first, failing that call AVO. You can probably get one from a specialty shop, but without knowing the size and thread it's going to be difficult. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Gravedigger Posted September 28, 2008 Author Share Posted September 28, 2008 I wish I remembered the guys name I bought the turbo from. I deleted all my messages once I received all the parts. Link to comment Share on other sites More sharing options...
PhilT Posted September 28, 2008 Share Posted September 28, 2008 You must have a paypal record, or someway of tracing the guy surely ? Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Gravedigger Posted September 28, 2008 Author Share Posted September 28, 2008 Yeah I went back to pay pal and found his email address. This all started with a rod bearing failure and buying a new sti block. Things have gotten out of control. I haven't had my car for almost a month now. Its all the little things. I waited for over a week for valve cover gaskets. I am now on a first name basis with Enterprise rental cars. Thanks for the help hopefully I can get things together soon. Link to comment Share on other sites More sharing options...
fonts Posted September 28, 2008 Share Posted September 28, 2008 Hmmm. I didn't have any problems at all with a very similar setup to yours. I did get the AVO turbo inlet which was a real bitch to get in. I also ordered a new (longer) oil feed line before the install. Took quite a bit of time but no issues at all with fitment on either the oil or inlet side. Hope all works out for you. Good luck. Link to comment Share on other sites More sharing options...
Gravedigger Posted September 28, 2008 Author Share Posted September 28, 2008 fonts did you remove the plastic intake manifold to get the AVO turbo inlet pipe to fit? It looks bigger than the stock unit and the stock unit was a tight fit. Are you running an AVO 420? Link to comment Share on other sites More sharing options...
Gravedigger Posted September 28, 2008 Author Share Posted September 28, 2008 Also I have a cobb up pipe that has no flex to it. What up pipe are you running? Link to comment Share on other sites More sharing options...
fonts Posted September 28, 2008 Share Posted September 28, 2008 fonts did you remove the plastic intake manifold to get the AVO turbo inlet pipe to fit? It looks bigger than the stock unit and the stock unit was a tight fit. Are you running an AVO 420? I did not remove the intake manifold. It was definitely bigger than the stock unit and was a bitch to get in. Just took our time and played and worked. Went in no problem .... just a PITA. Yes ... I'm running an AVO420. Link to comment Share on other sites More sharing options...
fonts Posted September 28, 2008 Share Posted September 28, 2008 Also I have a cobb up pipe that has no flex to it. What up pipe are you running? Grimmspeed. It is a flex pipe. Link to comment Share on other sites More sharing options...
Gravedigger Posted September 28, 2008 Author Share Posted September 28, 2008 I am ordering some parts tomorrow hopefully I can get my car running by the end of the week. AVO inlet pipe, Perrin Inlet pipe, anybody have any opinions one way or the other for fitment? Link to comment Share on other sites More sharing options...
fonts Posted September 28, 2008 Share Posted September 28, 2008 I believe that the AVO is a better piece all around. But hey that's what I'm running and that's just my opinion. Perrin did have some issues with the pipe collapsing in the past. I believe that it is now resolved. May be a little easier to get the Perrin into that tight space. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 20, 2008 Share Posted October 20, 2008 Any update did you get it in? Link to comment Share on other sites More sharing options...
Gravedigger Posted October 20, 2008 Author Share Posted October 20, 2008 Yeah I needed a new banjo bolt for the oil inlet pipe and a new air inlet pipe( the stock one was torn) I finally got it tuned at Top Speed in GA and they did a great job. I put 320hp to the wheels and it runs great. I much different car above 4k rpm. Thanks to AVO and Top Speed for the help. Link to comment Share on other sites More sharing options...
Gravedigger Posted October 20, 2008 Author Share Posted October 20, 2008 I think I could have run more boost they set it at 17.5 but I only had 4 miles on the new motor. I might go front mount and a new tune next summer. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 20, 2008 Share Posted October 20, 2008 Do you have a dyno graph you could post? What type of dyno were you tuned on? Mustang, Dynojet etc.. Oh I looked them up did scott siegel tune your car? Link to comment Share on other sites More sharing options...
Gravedigger Posted October 21, 2008 Author Share Posted October 21, 2008 I have a print out of the dyno graph but nothing online. It was a Dynojet dyno and Doug Wilks did the tuning. He stayed until almost 8 that night to get it done because I lived two hours away. I would highly recomend Doug and Top Speed. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 21, 2008 Share Posted October 21, 2008 Any way you could post it or send me a copy? Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 23, 2008 Share Posted October 23, 2008 Here is your dyno in JPG format: http://inlinethumb58.webshots.com/14969/2156957450074087040S600x600Q85.jpg Link to comment Share on other sites More sharing options...
Gravedigger Posted October 23, 2008 Author Share Posted October 23, 2008 I wander how much power I would get out a front mount and bigger injectors? Link to comment Share on other sites More sharing options...
PhilT Posted October 23, 2008 Share Posted October 23, 2008 I wander how much power I would get out a front mount and bigger injectors? A FMIC should net you around another 20whp, get tuned on 94 and you can see that increase to 50 whp. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
