Shotokan1509 Posted October 18, 2012 Share Posted October 18, 2012 Car up on stands, start to charge battery and brake pressure... Notice the rear wheels are turning?! Tried shift reverse then back to park but still doing it? Link to comment Share on other sites More sharing options...
ericem Posted October 18, 2012 Share Posted October 18, 2012 I notice sometimes when I park the car on a certain angle and I go to shut off the car it rolls back or forward. Usually when its cold though when everything is warmed up it does not do it. I think it is because there a small groves in the center diff clutch hub and sometimes they grab untill the unit is warmed up. Link to comment Share on other sites More sharing options...
underground000 Posted October 18, 2012 Share Posted October 18, 2012 failed parking pawl?? 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
Shotokan1509 Posted October 18, 2012 Author Share Posted October 18, 2012 I'll have to test once its back on its wheels.. just seemed very strange to me. I always set parking brake so if it is an issue ive not noticed Link to comment Share on other sites More sharing options...
fishbone Posted October 19, 2012 Share Posted October 19, 2012 It's normal. ericem, it's also normal for the car to roll a few inches forward or reverse after you've parked. Almost every transmission out there will do it, some more than others. I pull the e-brake before I release the brake pedal and that way the whole weight of the car doesn't rest on the parking pawl in the tranny. It also won't be a bitch to shift out of Park when you go to leave. Link to comment Share on other sites More sharing options...
GTTuner Posted October 19, 2012 Share Posted October 19, 2012 Normal. Parking brake and wheel chocks anytime you have the front wheels only off the ground. Link to comment Share on other sites More sharing options...
iNVAR Posted October 20, 2012 Share Posted October 20, 2012 you mean they turn when you use your hands to turn them, right? not that they're turning by themselves? if so, pretty sure it's normal Link to comment Share on other sites More sharing options...
underground000 Posted October 21, 2012 Share Posted October 21, 2012 Ahhhh OP never said car was in park gotta read lol 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
ericem Posted October 22, 2012 Share Posted October 22, 2012 It's normal. ericem, it's also normal for the car to roll a few inches forward or reverse after you've parked. Almost every transmission out there will do it, some more than others. I pull the e-brake before I release the brake pedal and that way the whole weight of the car doesn't rest on the parking pawl in the tranny. It also won't be a bitch to shift out of Park when you go to leave. yes yes I think you mis understood. When I put the vehicle in park and the engine is running foot OFF the brake pedal, but than go to shut off the car and bam the car suddenly rolls that NORMAL few inches you would expect only after I go to shut it off though with the car running it is like the rear wheels are being pushed ever so slightly. Link to comment Share on other sites More sharing options...
GTTuner Posted October 22, 2012 Share Posted October 22, 2012 The rear wheels are not connected to the parking pawl inside the trans. They are free to roll. In neutral on a lift, in park, the wheels will spin. Link to comment Share on other sites More sharing options...
