(Setup) MAP3 Sensor output -14.7 to 29.4 ??
phildog33
Hey just wanted to double check I set this up correctly.
Im using a MAP3 sensor, taped into the BOV tube.. and that sensor is connected to an Innovate SSI-4 so I can read boost off my VF52 turbo in my stage 3 suby.
Just wanted to attach this pic, to see if I set up the voltage swing from 0-5V on the 3 bar map to read -14.7 to 29.4 PSI.
IS that right?
http://phillipangert.com/dropbox/SSI4.jpg
  • 3 weeks later...
If nobody knows the answer you can figure it out for yourself... Buy or borrow a Tactrix cable, and log boost from the car and from this thing simultaneously. If the numbers agree, you've got it right. If they don't, tweak the settings until they do.
