the pizza Posted April 19, 2014 Share Posted April 19, 2014 What type of transmission and differential fluids do yall recommend for a 5mt leggy gt? Figured I'd post this cause autozone's computer couldn't bring up any recommendations and the local Subaru dealership is closed for the day. I'm guessing 75w-90 GL-5, but what about synthetic versus non-syn? Link to comment Share on other sites More sharing options...
GTTuner Posted April 19, 2014 Share Posted April 19, 2014 Subaru Xtra-s full synthetic in the gearbox, stuff is magic. Don't waste time with any other stuff, its all bullshit........it is magic. Freds beans sell quarts. you can use regular 75w-90 synthetic in the rear diff. Link to comment Share on other sites More sharing options...
GTborn01 Posted April 19, 2014 Share Posted April 19, 2014 Xtra-S to the best stuff you can get. Scottie's cocktail has mixed reviews so go for the proven stuff. In my area, it's about $12/quart and you will need 5 Link to comment Share on other sites More sharing options...
Brian3676 Posted April 19, 2014 Share Posted April 19, 2014 I used to run Redline, was nice. Now switched to Amsoil severe duty. Tranny has never shifted better. Link to comment Share on other sites More sharing options...
SleeperScoob Posted April 20, 2014 Share Posted April 20, 2014 *Thread Hijack* The Scoob dealer sells this magic Xtra-S juice, correct? I'm about to drain and fill my trans as well. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted April 20, 2014 Share Posted April 20, 2014 Make sure it's actually Extra-S. Subaru also sells a generic 75-90 gear oil that is NOT Extra-S. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
magnusonsubie Posted April 21, 2014 Share Posted April 21, 2014 Grimmspeed also makes a cocktail for transmission that supposedly works wonders. Might want to give that a try. I will be ordering it when I get my next paycheck Sent from my iPhone using Tapatalk 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
theflystyle Posted April 21, 2014 Share Posted April 21, 2014 Should mention for those casually reading, the extra-s is for manual trans only. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted April 21, 2014 Share Posted April 21, 2014 I used to run Redline, was nice. Now switched to Amsoil severe duty. Tranny has never shifted better. Been running Amsoil severe duty 75w-90 gear oil for over 210k. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
jay-d Posted April 22, 2014 Share Posted April 22, 2014 I used to run Redline, was nice. Now switched to Amsoil severe duty. Tranny has never shifted better. http://www.amsoil.com/shop/by-product/gear-lube/severe-gear-75w-90/?code=SVGQT-EA That stuff? I'm going to try this on my next fluid change. Link to comment Share on other sites More sharing options...
apexi Posted April 22, 2014 Share Posted April 22, 2014 I've run the fluid in the link above, it felt pretty good in my gearbox. Link to comment Share on other sites More sharing options...
Brian3676 Posted April 22, 2014 Share Posted April 22, 2014 Yup that's the stuff i use. Link to comment Share on other sites More sharing options...
baci Posted April 22, 2014 Share Posted April 22, 2014 +1 for Amsoil! Next oil change ill be Amsoil front to back. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 22, 2014 Share Posted April 22, 2014 If your going to buy 5 qt's of Extra-S and plan to keep the car, think about buying a 5 gallon pile. After just over two changes you've about paid for the 5 gallons. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
chisav Posted April 23, 2014 Share Posted April 23, 2014 Just a FYI but Subaru Dealerships do sell Extra S in quarts now. I got a bottle last week for $10. Link to comment Share on other sites More sharing options...
apexi Posted April 23, 2014 Share Posted April 23, 2014 What type of bottle was it in? Do you have a picture or part number? Link to comment Share on other sites More sharing options...
sbacon86 Posted April 23, 2014 Share Posted April 23, 2014 I work at an auto repair shop and just asked my BG rep to bring me some of the syncro shift...didn't have any shifting issues, but wanted to go ahead and change it out. also called the shop where all of the service was done on mine (05 gt 5spd man) and they had used the same product before. no issues so far and i have 132.000!! Link to comment Share on other sites More sharing options...
sbacon86 Posted April 23, 2014 Share Posted April 23, 2014 oh and i also used bg gear oil for the rear diff.... Link to comment Share on other sites More sharing options...
chisav Posted April 25, 2014 Share Posted April 25, 2014 What type of bottle was it in? Do you have a picture or part number? I did some searching and it seems like I was duped by the parts guy. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 25, 2014 Share Posted April 25, 2014 Are you sure that is Extra-S ? Have you seen the 5 gallon can ? it's gold and black and I believe it say's Extra-S on it. I'll check when I get home. You may be able to find a picture of the can in my link in my sig. I can't view pictures here at work. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
chisav Posted April 25, 2014 Share Posted April 25, 2014 Are you sure that is Extra-S ? Have you seen the 5 gallon can ? it's gold and black and I believe it say's Extra-S on it. I'll check when I get home. You may be able to find a picture of the can in my link in my sig. I can't view pictures here at work. Removed the photos and the post so there isn't any misinformation. I checked it and I got some info on NASOIC. Looks like it's an alternative to Extra-S. Damn parts guy duped me. Link to comment Share on other sites More sharing options...
chisav Posted April 25, 2014 Share Posted April 25, 2014 Same thing I got from the dealership. Found these photos on NASIOC. Shouldn't have taken the parts guy's word for it. Link to comment Share on other sites More sharing options...
chisav Posted April 25, 2014 Share Posted April 25, 2014 Are you sure that is Extra-S ? Have you seen the 5 gallon can ? it's gold and black and I believe it say's Extra-S on it. I'll check when I get home. You may be able to find a picture of the can in my link in my sig. I can't view pictures here at work. Yeah I saw your photo and saw my bottle and it definitely did not look as snazzy. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 25, 2014 Share Posted April 25, 2014 Yea, after I posted, I was thinking may be I should have told you my story when I ordered the Extra-S. The first parts guy thought it was all the same stuff. Luckily they know me and when the supervisor saw my name and the order he questioned what the guy ordered, called me to verify what I wanted. He cancelled that order and got me what I wanted. Funny how that letter say's it's an alternitive to the 5 gallon can of Extra-S, makes it sound like they just package the Extra-S in qt's now. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
chisav Posted April 25, 2014 Share Posted April 25, 2014 Yea, after I posted, I was thinking may be I should have told you my story when I ordered the Extra-S. The first parts guy thought it was all the same stuff. Luckily they know me and when the supervisor saw my name and the order he questioned what the guy ordered, called me to verify what I wanted. He cancelled that order and got me what I wanted. Funny how that letter say's it's an alternitive to the 5 gallon can of Extra-S, makes it sound like they just package the Extra-S in qt's now. I'm guessing that's how the parts guy got confused. I honestly didn't even look at the bottle until I was posting the photos, I just took his word for it. When I didn't see synthetic, I googled the part number and voila not Extra-S. Lucky I haven't put it in yet. Link to comment Share on other sites More sharing options...
