Deno Posted December 23, 2012 Share Posted December 23, 2012 I am replacing my tranns dunno if I had too but Icant find a solution to my grindind noise issue. will i need any seal kits ie tail shaft seal?. And is it easier to pull the converter off and bolt it to the engine or leave it in the tranns then slide it onto the engine this will be done wth the engine still in the car any tips will be a great help. Link to comment Share on other sites More sharing options...
doccrowley Posted December 23, 2012 Share Posted December 23, 2012 Converter will stay in/on the tranny and you won't need to replace a tail shaft seal unless yours is leaking or damaged on the removal. Link to comment Share on other sites More sharing options...
Deno Posted December 23, 2012 Author Share Posted December 23, 2012 ok thanx . do you think my actual tranns be ok if the damage is in the converter ,or has metal shards from it has spread throught the whole system thus a complete transplant Link to comment Share on other sites More sharing options...
