semsub Posted June 19, 2012 Share Posted June 19, 2012 Hi all. This topic is following to my topic about ghoust CEL http://legacygt.com/forums/showthread.php/help-needed-intake-manifold-hose-186461.html?t=186461 After checking all by myself and talking to Shamar made my mind to ask for some more opinions. As I said in previous topic , after I plugged back fuel VAC line hose back to manifold strange things happened. After that my AF corrections in LV logs was always negative. I checked all hoses that I can without dissasembling anything, nothing. Also no CEL codes stored. But only when green connectors is plugged LV shows at the same time 3 temp codes : P1518, P1152, P1153. Shamar told me that according to logs there is a leak or/and bad O2 sensor. Today I was cruising with romraider for about 20 min , just to see AF corrections in real time. All I can say, that on first idle (especially on cold) AF goes always to negative numbers (max number was - 20,40) When I was cruising like grandma at about 30mph , AF jumps sometimes like crazy , from - 17,55 to + 15,40. When I floored it from 10mph to 40 mph, AF slowly moves between -3,55 and + 2,33. Also my idle (when car warmed up) was much rougher then ussually, passenger seat was vibrating like vibro massage chair I put some LV logs here and screenshot of my RR dashboard (no romraider logs) I just need some opinions on bad O2 sensor and leak, because I am short on money now and all mechanics are really stupid , they will as ussually say to replace many things , that no need to replace.. And so hard to find good boost leak checker:mad: Anyway please tell me your opinions and what would you check first? Can this be exhaust leak also? Could bad O2 sensor and leak cause problems that I wrote in http://legacygt.com/forums/showthread.php/help-needed-intake-manifold-hose-186461.html?t=186461 ? Thanks:) P.S And yep I will swap my stock uppipe for aftermarket one on friday, maybe this matters.. Link to comment Share on other sites More sharing options...
bmx045 Posted June 20, 2012 Share Posted June 20, 2012 1. did you perform a boost leak test? 2. were you tuned with a leak, and now that its fixed, are seeing trim issues? 3. those LV's do not show an issue 4. your af sensor 1 afr will bounce around 14.7, up and down normally. Recheck the LV after more driving/days to see where they settle, it can take time. Link to comment Share on other sites More sharing options...
