claymore_6r Posted September 4, 2012 Share Posted September 4, 2012 Yesterday on the way back from New Hampshire I filled my about 7 gallons of 91 instead of 93 because Irving's don't carry 93. Will this hurt the motor? I was low on gas at the time and that was the only gas station around. Thanks Link to comment Share on other sites More sharing options...
Drift Motion Posted September 4, 2012 Share Posted September 4, 2012 is your car tuned only for 93? Link to comment Share on other sites More sharing options...
blongo804 Posted September 4, 2012 Share Posted September 4, 2012 Like Drift Motion is getting at, if you're tuned for 93, you have a chance to make knock (I believe..correct me if i'm wrong) if you put 91 in the car. Otherwise, you're fine. I'm being tuned for 91 for this exact reason. I'm more commonly going to run into 91 than 93 if i'm in dire need of gas for some reason. Link to comment Share on other sites More sharing options...
joeblow Posted September 4, 2012 Share Posted September 4, 2012 An occasional tank of less than 93 will not make a difference to your motor as long as you don't get stupid with it. Just try your best to keep boost to a minimum and burn through most of it, then fill her up with 93. The ECU should be able to adjust timing within reason to compensate for the octane difference provided you aren't beating the piss out of it. You'll want to reset the ECU after you put the 93 in to get rid of the learned knock correction and get your timing back though. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
jfg22557 Posted September 4, 2012 Share Posted September 4, 2012 ^this just keep your right foot out of it and you'll be ok. I run into the same issue every July when I go up to Maine for the New England Forest Rally, but this year I started using Torco Accelerator (essentially race fuel concentrate) so I dont have to be easy on it anymore:D Link to comment Share on other sites More sharing options...
claymore_6r Posted September 5, 2012 Author Share Posted September 5, 2012 Thanks guys...That was a dumb move...I occasionally gunned it when I came back but now it's about half a tank left. I filled about 7 gallons worth of 91. Yes the car is tuned at stage 2 with 93. Should I wait until low gas light come on to refill? Also I'm getting a process west intercooler..should I wait to get that install before re-tuning it? OR should I just re-tune it when I refill with 93? Thanks in advance! Link to comment Share on other sites More sharing options...
ripemeat Posted September 5, 2012 Share Posted September 5, 2012 put 93 in when the gas light comes on, fill it up all the way. install PW, get tuned. Link to comment Share on other sites More sharing options...
dr_sharp Posted September 5, 2012 Share Posted September 5, 2012 OR should I just re-tune it when I refill with 93? I think you are misunderstanding what a 'tune' is in this context. Once you refill with 93, all will be back to normal. Your tune is already programmed onto the ECU and putting different fuel in the car doesn't change that. A retune would only ever be required after changing parts, like in your case with the PW TMIC. lol Link to comment Share on other sites More sharing options...
Max Capacity Posted September 5, 2012 Share Posted September 5, 2012 I tend to run the car as low as I can before filling up with 93. The same problem happens when you go to Maine, like NH they don't have 93. Yes, re-tune after the PW TMIC 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
claymore_6r Posted September 5, 2012 Author Share Posted September 5, 2012 Sounds great guys..Thanks again! I'm still learning so just bare with me...lol When I install PW TMIC should I get it tuned by a shop or could I do that myself? I'm not good with numbers. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 5, 2012 Share Posted September 5, 2012 Contact NRW, he has a connection with a good/great Tuning shop in your area. You want to have it tuned right the first time. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
