Zac88 Posted June 10, 2014 Share Posted June 10, 2014 last night I was trying to diagnose a clunk in the rear. When I was pulling up and down on the sway bar the subframe bushings and diff bushings were moving quite a bit. Also looks like ill need the AVO sway bar mounts. Does anyone make those bushings for the LGT? I would like to remove the subframe and replace them all. Link to comment Share on other sites More sharing options...
Underdog Posted June 10, 2014 Share Posted June 10, 2014 Here you go sir. Please let me know if I can quote any of these for you. http://imageshack.com/a/img14/6536/bpblwhitelineproductgui.jpg The Crimson Dynamo Link to comment Share on other sites More sharing options...
Zac88 Posted June 10, 2014 Author Share Posted June 10, 2014 Looking at that chart it seems like the bushings I want aren't available. I want the bushings for the 4 mounting points to the chassis Link to comment Share on other sites More sharing options...
Underdog Posted June 11, 2014 Share Posted June 11, 2014 My bad, I thought you wanted the bushings for the diff to the crossmember (KDT905 and KDT906). The Crimson Dynamo Link to comment Share on other sites More sharing options...
Zac88 Posted June 11, 2014 Author Share Posted June 11, 2014 No worries I appreciate the help. But does anyone make the bushings im looking for? Link to comment Share on other sites More sharing options...
Underdog Posted June 12, 2014 Share Posted June 12, 2014 I don't know of any made specifically for our platform. The Perrin WRX/STI subframe lockdown bushings may fit, but I have not compared the subframes between models. For $27.90+shipping it is worth a shot. You can always sell them off on NASIOC if it doesn't work. Torque Solutions also makes a set but it is a tiny bit more expensive for essentially the same thing - I'd go with Perrin. The Crimson Dynamo Link to comment Share on other sites More sharing options...
