Tuning in Queens?
TheMahFromTheU
Good Morning All,
I'm in the process of building my LGT, I've opted for VF48 rather then VF52, with 650cc injectors, process west TMIC, SPT exhaust, Invidia up/downpipe (catless)...
Where can a fellow go to get tuned in Queens? Or do I really need to drive to EFI Logic in CT?
  • Replies 60
  • Created
  • Last Reply
Try these two:
M.R. Performance
84 New York Ave, Westbury NY
516.280.7211
http://www.mrpbuilt.com/
M.R. Performance works in association with Visconti Tuning in CT
John is the Master Tuner @ Visconti and tunes cars out in Westbury to.
Tell him Mike with the 3.6 H6 sent you.
Visconti Tuning
191 Post Road West, Westport CT
203.856.9946
http://www.vtune.us
Dave at metric is our go to tuner in LI. Known him for 10+ years.
-Mike Paisan
http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
Try these two:
M.R. Performance
516.280.7211
Visconti Tuning
203.856.9946
http://www.vtune.us
There's also the other John at MR that does OS tuning, both Ryan and him are great to deal with.
  • 1 month later...
Hey all, I have another question about tuning? So as I said my motor is totally being rebuilt, the car has stock dp/up but I plan on installing new motor along with new dp/up with exhaust - my question is once all of this is installed should I get tuned from jump or break in the motor first then get tuned?
If you don't have a stock setup, you need a base-tune/breakin map in order to break it in properly. Then have the car re-checked over and pro-tuned after breakin.
-Mike Paisan
-Mike Paisan
Is it safe to drive the car once its done to a shop that can provide me with such a map? This car is going through a total transformation..
I wouldn't.
When we do a motor replacement/upgrade or even certain bolt-ons we require the customers to get a base map prior to us even starting the car up.
You can drive with no map forever, but it isn't a good idea.
-Mike Paisan
I wouldn't.
-Mike Paisan
So when everything gets installed what am I suppose to do, flatbed it back home and then flatbed it to a shop for a tune?
I think there's two different topics being discussed here...
SHould you mod a car before the break-in period is one of them i BELIEVE... i would go with no.
What mike paisan was sayin', is that when you modify the car, you need the proper tune on it... So when you DO mod it (hopefully after breakin) make sure your tuner gives you a BASE map for the mods you have...
Depending on what the "build" is you often times need to have mods on it right from the get-go. Any of the major tuners out there who are worth their salt can send you a Break-in or Base Tune that will allow you to properly break it in for the mods you have and drive it to their tuning shop.
Infamous Tuning & Performance will build an e-tune base map, EFI Logics, Precision, and MSPT out on LI can all provide base maps for you to break in a rebuilt motor based on the specific mods you have.
-Mike Paisan
I get that, but what I'm saying is - the motor is being rebuilt from scratch so my builder suggested if I wanted to change anything else while car is apart now would be a good time, so having said that: New motor goes in, new dp, new up, new exhaust, new turbo, new tmic, new diff bushings from frank_ster, new drop in panel filer for intake.
total overhaul.
-Mike Paisan
Thanks Mike.
While we are talking about "building" it, I hope you are building it with upgraded forged pistons. If you want to tell us what components you are using we can help you see if there is anything missing in the mix that could be beneficial.
-Mike Paisan
-Mike Paisan
Brand new EJ257 block halves with the following:
Manley connecting rods
Wiseco forged pistons (standard bore 99.50)
ACL main/rod bearings
ARP head studs
BustedFinger Motorsports TGV deletes
OEM nitrated crank
Heads:
Port n poilish
EJ255/57 head gaskets
Brian Crower Camshafts 272/272
Brian Crower springs/retainers
Brian Crower cam gears
Invidia downpipe/uppipe
Invidia Q300 exhaust
Diff/tranny bushings (frank_ster)
STi OEM TMIC, OEM STi IM
Drop in panel filter
That's all I can remember off the top of my head....
ARP head studs
OEM nitrated crank
Heads:
Port n poilish
I would not start or drive that setup without a base map from a reputable tuner on there.
-Mike Paisan
Also I would consider a valve body upgrade to go along with the extra power. You also have an automatic, so I would suggest an ATF cooler, ATF Temp Gauge and Redline High Temp ATF as well. This will all be a good matchup with the upgraded motor.
-Mike Paisan
